how can I download Ubuntu and also keep all my files saved to my laptop at the same time? I have a bunch of apps that I don't want to get deleted and I've already downloaded the iOS on my USB and before I do anything I need to know how I can download it without anything getting removed.
Short Answer:
Run the Live environment, and DO NOT INSTALL: https://www.ubuntu.com/download/desktop/try-ubuntu-before-you-install
Otherwise, follow the links Eliah provided.
Long Answer:
Installing an OS can be a big deal; you can easily run into trouble either by your own mistake or by getting unlucky and the installer fails or messes something up. Then you may have to get into some really geeky troubleshooting, depending on how bad it is.
Ubuntu has been refined and is an attempt to make Linux easy and accessible for anyone. If you're willing to try that, then go ahead and install as they guide you to.
However, if you are this concerned already, and the many mistakes you made using technical terms were in fact from your best effort of explaining your problem, I warn you that you do not sound experienced enough to handle any issues that may come up, and I even fear you being prone to making an accident that can make you lose things.
Recommendation: If this is your only / main PC, don't install it; just run the Live environment to try it out. If you want to install it, do it on an older computer you don't care about.
If you're willing to risk it on your main PC, then simply follow instructions carefully, exactly, and go ahead! You SHOULD be fine, Ubuntu is pretty good, and you will never learn if you don't try! BUT, always be safe: back up your files, know how to re-install all the programs you want, etc., in case everything gets - or needs to be - wiped.
Rhoi
  • 16
