While doing a software update (currently using 16.04), everything in the window went grey during install, and is apparently stuck on "configuring shim-signed". I am not wanting to cancel installation...is this just a matter of patience? How long should I wait? What should I do?
Asked
Active
Viewed 2,361 times
I had to end the Software Updater and reboot, then use terminal to do sudo apt-get update
Then, I also followed the instructions to run dpkg --configure -a
After that, I did sudo apt-get update again, followed by sudo apt-get upgrade
This worked for me, but I'm not saying definitively that this will fix your issue as well.
