I recently installed Bitcoin Core on my Ubuntu 16.04 system. It's taking up too much disk space. How do I completely uninstall the software and remove data to free up my hard drive space?
earthmeLon
  • 11,658
ckubuntu
  • 61
Remove bitcoin:
  1. sudo apt-get remove bitcoind
Alternatively, you could just disable bitcoind from starting at startup:
  1. sudo systemctl disable bitcoind
Remove extra files:
If you remove your .bitcoin directory, you are removing your wallets/addresses and access to any BTC in those wallets, as well as the blockchain history.
When you run bitcoind, it typically creates a .bitcoin directory in the home directory of the running user. Depending on your setup, this could be a user named bitcoin, or be your user.
  1. rm -rf /path/to/.bitcoind/
If you're not sure where this path is, you could run the following commands to help find it:
  1. sudo updatedb
  2. sudo locate .bitcoind
More specifically, the blocks take up a lot of space and are found in .bitcoind/blocks/.
earthmeLon
  • 11,658
In my version of Ubuntu (18.1) the files are located in .bitcoin and not in .bitcoind so use these commands:
  1. rm -rf /path/to/.bitcoin/
zx485
  • 2,865
Fred
