I make a fresh install of LAMP components on Ubuntu. The following installations are done
apt-get install php
apt-get install php-mysql
apt-get install mysql-server
apt-get install apache2
apt-get install libapache2-mod-php7.0
apt-get install dolibarr
apt-get install php7.0 php5.6 php5.6-mysql php-gettext php5.6-mbstring php-xdebug libapache2-mod-php5.6 libapache2-mod-php7.0
apt-get install python-software-properties pkg-config software-properties-common
When I access <MyIP>/dolibarr/htdocs, I get the PHP code displayed and not executed.
When I access <MyIP>/test.php, I get the PHP code below executed and PHP info displayed:
<?php
phpinfo();
Both this test.php and Dolibarr are placed in /var/www
Apache root dir is set in /etc/apache2/sites-enabled/000-default.conf as follows:
<VirtualHost *:80>
# The ServerName directive sets the request scheme, hostname and port that
# the server uses to identify itself. This is used when creating
# redirection URLs. In the context of virtual hosts, the ServerName
# specifies what hostname must appear in the request's Host: header to
# match this virtual host. For the default virtual host (this file) this
# value is not decisive as it is used as a last resort host regardless.
# However, you must set it for any further virtual host explicitly.
#ServerName www.example.com
ServerAdmin webmaster@localhost
DocumentRoot /var/www
Because I wanted to make sure PHP version was not implied, I tried this tuto and swiched between PHP 7.0 and PHP 5.6.
I'm stuck here. Any idea please folks ?
