I have cmus music player installed and I really like it.
I need to run a command by pressing a key, for example CTRL+F so it will open browser and search a lyrics for currently playing song.
The command might be something like:
/usr/bin/google-chrome --new-tab http://search.azlyrics.com/search.php?q=[name-of-the-song]
Is it possible and if so where and how can I define such command ?
UPDATE:
Sorry for not being clear enough. This has nothing to do with global system keyboard shortcuts (as I know how to made them). Let me explain:
I am running cmus music player and within it I am selecting a song to play and play it. Then I want to run an "external command" for this song. By running some key shortcut (while this song is played) I want to run a command that will search lyrics for this song.
To setup a macro, go to SystemSettings > Keyboard > Shortcuts
Click on + and name your macro & add the command associated with it.
Click again and press your keys to associate it with the command- in your case,
google-chrome http://search.azlyrics.com/search.php?q=[name-of-the-song]
Melcalc
  • 31
You can use the Ubuntu's keyboard key assignment.
Create the script. Then assign a keyboard shortcut to it.
The script
Example (findsong.sh):
#!/bin/bash
/usr/bin/google-chrome --new-tab http://search.azlyrics.com/search.php?q=backpack
Assign Key shortcut:
Type keyboard in the Ubuntu Launch Button.
  • On the GUI interface click keyboard then click the + key to Add a new Shortcut.
  • Type in a Description and a full path to the script; then click apply
  • Click on the right column (disabled by default) then hit the key sequence you want to run the script. For the test I hit Ctrl+Shift+F. This is because Ctrl+F is already taken.
Now when you hit the shortcut will run.
L. D. James
  • 25,444
