Since I've upgraded to 11.10, I cannot get my jungledisk application to work.
Asked
Active
Viewed 680 times
If you are running a 64-bit install, run the following command post install of jungledisk.
sudo ln -s /usr/lib/x86_64-linux-gnu/libnotify.so.4 /usr/lib/libnotify.so.1
Mike Stonis
- 121
jungledisk is available from the Jungle Disk downloads page.
Open a terminal and download jungledisk
32bit Ubuntu
cd ~ && wget https://downloads.jungledisk.com/jungledisk/junglediskdesktop_316-0_i386.deb
64bit Ubuntu
cd ~ && wget https://downloads.jungledisk.com/jungledisk/junglediskdesktop_316-0_amd64.deb
(Re) install it and remove the installer
sudo dpkg -i ~/junglediskdesktop*.deb && rm ~/junglediskdesktop*.deb
You need to create this a symlink link to libnotify.so.4 with the name libnotify.so.1 inside /usr/lib.i386-linux-gnu/, to it with this command
cd /usr/lib/i386-linux-gnu/ ; sudo ln -s ./libnotify.so.4 libnotify.so.1
After this jungledisk is installed you can launch it from the terminal with junglediskdesktop or by looking for it on the dash.
Bruno Pereira
- 74,715
Rackspace has posted an extensive post on this matter with a solution (but not yet a promise to recompile their client software):
Bryce
- 2,007
