13
Ubuntu 16.04.1 LTS
I don't know what I did, everything was working fine, but since today my bash doesn't autocomplete anymore when I use sudo. I can use the autocompletion as normal user, I can use autocompletion as root, I can use autocompletion for directories with sudo, but I can't use autocompletion for files if I use sudo.
If I write:
$sudo vim /etc/ssm[TAB]
it will autocomplete to:
$sudo vim /etc/ssmtp/
but then if I hit [TAB] again, even twice like I was used to list the files in the directory, nothing happens. I already checked and I have the autocompletion enabled in the user .bashrc and also in /etc/bash.bashrc
Try firstly reinstalling the bash-completion package with:
sudo apt-get install --reinstall bash-completion
Then backing up your .bashrc file:
mv ~/.bashrc ~/.bashrc.bak
Finally, replace your .bashrc file with the default from /etc/skel/.bashrc by using:
cp /etc/skel/.bashrc ~/
This will ensure the following 'complete' config is restored within the file:
# enable programmable completion features (you don't need to enable
# this, if it's already enabled in /etc/bash.bashrc and /etc/profile
# sources /etc/bash.bashrc).
if ! shopt -oq posix; then
  if [ -f /usr/share/bash-completion/bash_completion ]; then
    . /usr/share/bash-completion/bash_completion
  elif [ -f /etc/bash_completion ]; then
    . /etc/bash_completion
  fi
fi
Also check both the containing folder and file permissions of /etc/bash.bashrc and ~/.bashrc - ownership should be root:root and yourusername:yourusergroup respectively. The permissions of the files are important as the shell only uses your own privilege level to auto-complete commands. Elevated permissions such as when sudo is invoked are only used after the command is committed by pressing enter.
Add
complete -cf sudo
to your .bashrc and .bash_profile. Autocompletion will work on next login
Pablo Bianchi
  • 17,371
guest
  • 71
I find out that the problem wasn't about autocomplete, but just a matter of permissions. The folder is own by root:mail instead of root:root as most of the directories in /etc and my user wasn't in the mail group. Once I added the user to the right group it worked. I just don't understand why the command with sudo in front of it didn't superseded the group...
