I've used ssh before and password access from my new asus k53by laptop with a fresh 11.10 install to dev server works fine.
I wanted to set up key access for added security and ease of scripting and I did the following:
paul@paul-K53BY:~/.ssh$ ssh-keygen
Generating public/private rsa key pair.
Enter file in which to save the key (/home/paul/.ssh/id_rsa):
Enter passphrase (empty for no passphrase):
Enter same passphrase again:
Your identification has been saved in /home/paul/.ssh/id_rsa.
Your public key has been saved in /home/paul/.ssh/id_rsa.pub.
The key fingerprint is:
7e:91:b2:2b:a9:bc:f8:11:d1:aa:ea:41:c5:1a:39:ff paul@paul-K53BY
paul@paul-K53BY:~/.ssh$ ssh-copy-id -i id_rsa.pub 10.1.1.28
paul@10.1.1.28's password:
Now try logging into the machine, with "ssh '10.1.1.28'", and check in:
~/.ssh/authorized_keys
to make sure we haven't added extra keys that you weren't expecting.
paul@paul-K53BY:~/.ssh$ ssh 10.1.1.28
  • Everything seemed to work but I still needed to use the password. I also wanted a convenient handle for the server (without the hassle of DNS) so I set up ~/.ssh/config as follows:
    Host dev
    HostName 10.1.1.28
    PasswordAuthentication no
    PubkeyAuthentication yes
  • ssh dev then failed:
    paul@paul-K53BY:~/.ssh$ ssh dev
    Permission denied (publickey,password).
  • Switching password back on showed that ssh dev works fine still with the password.
    paul@paul-K53BY:~/.ssh$ ssh -vvv dev
    OpenSSH_5.8p1 Debian-7ubuntu1, OpenSSL 1.0.0e 6 Sep 2011
    debug1: Reading configuration data /home/paul/.ssh/config
    debug1: Applying options for dev
    debug1: Reading configuration data /etc/ssh/ssh_config
    debug1: Applying options for *
    debug2: ssh_connect: needpriv 0
    debug1: Connecting to 10.1.1.28 [10.1.1.28] port 22.
    debug1: Connection established.
    debug3: Incorrect RSA1 identifier
    debug3: Could not load "/home/paul/.ssh/id_rsa" as a RSA1 public key
    debug2: key_type_from_name: unknown key type '-----BEGIN'
    debug3: key_read: missing keytype
    debug3: key_read: missing whitespace
    debug2: key_type_from_name: unknown key type '-----END'
    debug1: identity file /home/paul/.ssh/id_rsa type 1
    debug1: Checking blacklist file /usr/share/ssh/blacklist.RSA-2048
    debug1: Checking blacklist file /etc/ssh/blacklist.RSA-2048
    debug1: identity file /home/paul/.ssh/id_rsa-cert type -1
    debug1: identity file /home/paul/.ssh/id_dsa type -1
    debug1: identity file /home/paul/.ssh/id_dsa-cert type -1
    debug1: identity file /home/paul/.ssh/id_ecdsa type -1
    debug1: identity file /home/paul/.ssh/id_ecdsa-cert type -1
    debug1: Remote protocol version 2.0, remote software version OpenSSH_5.3p1 Debian-3ubuntu7
    debug1: match: OpenSSH_5.3p1 Debian-3ubuntu7 pat OpenSSH*
    debug1: Enabling compatibility mode for protocol 2.0
    debug1: Local version string SSH-2.0-OpenSSH_5.8p1 Debian-7ubuntu1
    debug2: fd 3 setting O_NONBLOCK
    debug3: load_hostkeys: loading entries for host "10.1.1.28" from file "/home/paul/.ssh/known_hosts"
    debug3: load_hostkeys: found key type RSA in file /home/paul/.ssh/known_hosts:1
    debug3: load_hostkeys: loaded 1 keys
    debug3: order_hostkeyalgs: prefer hostkeyalgs: ssh-rsa-cert-v01@openssh.com,ssh-rsa-cert-v00@openssh.com,ssh-rsa
    debug1: SSH2_MSG_KEXINIT sent
    debug1: SSH2_MSG_KEXINIT received
    debug2: kex_parse_kexinit: ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1,diffie-hellman-group1-sha1
    debug2: kex_parse_kexinit: ssh-rsa-cert-v01@openssh.com,ssh-rsa-cert-v00@openssh.com,ssh-rsa,ecdsa-sha2-nistp256-cert-v01@openssh.com,ecdsa-sha2-nistp384-cert-v01@openssh.com,ecdsa-sha2-nistp521-cert-v01@openssh.com,ssh-dss-cert-v01@openssh.com,ssh-dss-cert-v00@openssh.com,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,ssh-dss
    debug2: kex_parse_kexinit: aes128-ctr,aes192-ctr,aes256-ctr,arcfour256,arcfour128,aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,aes192-cbc,aes256-cbc,arcfour,rijndael-cbc@lysator.liu.se
    debug2: kex_parse_kexinit: hmac-md5,hmac-sha1,umac-64@openssh.com,hmac-ripemd160,hmac-ripemd160@openssh.com,hmac-sha1-96,hmac-md5-96
    debug2: kex_parse_kexinit: none,zlib@openssh.com,zlib
    debug2: kex_parse_kexinit: first_kex_follows 0
    debug2: kex_parse_kexinit: reserved 0
    debug2: kex_parse_kexinit: diffie-hellman-group-exchange-sha256,diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1,diffie-hellman-group1-sha1
    debug2: kex_parse_kexinit: ssh-rsa,ssh-dss
    debug2: mac_setup: found hmac-md5
    debug1: kex: server->client aes128-ctr hmac-md5 none
    debug1: kex: client->server aes128-ctr hmac-md5 none
    debug1: SSH2_MSG_KEX_DH_GEX_REQUEST(1024<1024<8192) sent
    debug1: expecting SSH2_MSG_KEX_DH_GEX_GROUP
    debug2: dh_gen_key: priv key bits set: 123/256
    debug2: bits set: 500/1024
    debug1: SSH2_MSG_KEX_DH_GEX_INIT sent
    debug1: expecting SSH2_MSG_KEX_DH_GEX_REPLY
    debug1: Server host key: RSA eb:f9:56:b8:ae:b0:de:27:92:06:8f:ac:c1:43:e4:64
    debug1: Host '10.1.1.28' is known and matches the RSA host key.
    debug1: Found key in /home/paul/.ssh/known_hosts:1
    debug2: bits set: 511/1024
    debug1: ssh_rsa_verify: signature correct
    debug2: kex_derive_keys
    debug2: set_newkeys: mode 1
    debug1: SSH2_MSG_NEWKEYS sent
    debug1: expecting SSH2_MSG_NEWKEYS
    debug2: set_newkeys: mode 0
    debug1: SSH2_MSG_NEWKEYS received
    debug1: Roaming not allowed by server
    debug1: SSH2_MSG_SERVICE_REQUEST sent
    debug2: service_accept: ssh-userauth
    debug1: SSH2_MSG_SERVICE_ACCEPT received
    debug2: key: /home/paul/.ssh/id_rsa (0xb9434eb0)
    debug2: key: /home/paul/.ssh/id_dsa ((nil))
    debug2: key: /home/paul/.ssh/id_ecdsa ((nil))
    debug1: Authentications that can continue: publickey,password
    debug3: start over, passed a different list publickey,password
    debug3: preferred gssapi-keyex,gssapi-with-mic,publickey,keyboard-interactive
    debug3: authmethod_lookup publickey
    debug3: remaining preferred: keyboard-interactive
    debug3: authmethod_is_enabled publickey
    debug1: Next authentication method: publickey
    debug1: Offering RSA public key: /home/paul/.ssh/id_rsa
    debug3: send_pubkey_test
    debug2: we sent a publickey packet, wait for reply
    debug1: Trying private key: /home/paul/.ssh/id_dsa
    debug3: no such identity: /home/paul/.ssh/id_dsa
    debug1: Trying private key: /home/paul/.ssh/id_ecdsa
    debug3: no such identity: /home/paul/.ssh/id_ecdsa
    debug2: we did not send a packet, disable method
    debug1: No more authentication methods to try.
All that output is telling me something but I'm not sure what. What have I done wrong and why can't I get this ssh by key to work?
There seem to be quite a few questions here about 11.10 ssh/key access issues but I could not see anything I could try anywhere that might solve this for me.
Jorge Castro
  • 73,717
Whippy
  • 791
Firstly,
A public key does not start with the '-----BEGIN' words. Those are the words found in a private key.
Secondly, are you sure that this worked:
try:
ssh-copy-id 10.1.1.28
(this will default to ~/.ssh/id_rsa.pub. I am not sure if the complete path is required or not).
Thirdly, is your home folder on the server encrypted? If it is, then you need to physically log in on the server and keep this session open at all times. Then, when you ssh from your machine to the server, the ssh keys will be automatically used
rigved
  • 2,377
