18
Where does the rename command come from?
user@host> dpkg -S /usr/bin/rename
dpkg-query: no path found matching pattern /usr/bin/rename
guettli
  • 1,765
Surprisingly, it comes from the rename package.
pilot6@Pilot6:~$ ls -l /usr/bin/rename
lrwxrwxrwx 1 root root 24 окт 17  2013 /usr/bin/rename -> /etc/alternatives/rename
pilot6@Pilot6:~$ ls -l /etc/alternatives/rename
lrwxrwxrwx 1 root root 20 апр 29  2016 /etc/alternatives/rename -> /usr/bin/file-rename
pilot6@Pilot6:~$ dpkg -S /usr/bin/file-rename
rename: /usr/bin/file-rename
Fabby
  • 35,017
Pilot6
  • 92,041
12
You will probably find that it's a symbolic link that is managed by the update-alternatives mechanism:
$ ls -l $(which rename)
lrwxrwxrwx 1 root root 24 Jun 29  2016 /usr/bin/rename -> /etc/alternatives/rename
You can see the optional implementations using
$ update-alternatives --list rename
/usr/bin/prename
and can choose between implementations using
update-alternatives --config rename
FWIW file-rename is provided by the rename package, whereas the original prename is provided by perl itself. From apt-cache show rename:
This package provides both a perl interface for renaming files (File::Rename) and a command line tool 'rename' which is intended to replace the version currently supplied by the perl package.
As if this was not already confusing enough, you may also come across yet another rename from the util-linux package - see What's with all the renames?
steeldriver
  • 142,475
If we're talking about /usr/bin/rename, which is a pretty nifty perl script, then rename command belongs to its own separate package.
rename:
  Installed: 0.20-4
  Candidate: 0.20-4
  Version table:
 *** 0.20-4 500
        500 http://archive.ubuntu.com/ubuntu xenial/main amd64 Packages
        500 http://archive.ubuntu.com/ubuntu xenial/main i386 Packages
        100 /var/lib/dpkg/status
In case of Korn shell and its derivatives, rename is a shell built-in command.
$ echo $SHELL
/bin/mksh
$ type rename
rename is a shell builtin
