I changed the permission of the /usr to 400 and now I am not able to use sudo. How do I revert this and fix it?
- 72,312
- 1
- 1
- 1
Well - so you made /usr readable only to root, I guess (if no further changes). More over - you removed "x" by that which made the folder pretty much not accessible. Hence you can't now - as regular user - run sudo, which, if I remember correctly, is in /usr/bin/.
The best idea for now would be to start a system from LiveCD, mount your disk/filesystem and change the permissions back to 755.
And next time to be more careful with this kind of changes ;)
- 1,921
- 12
- 10
If you have things resolved, assign a password to the root user so you can login directly as root should you ever need to.
I remember that I got a similar problem a few years ago, and the solution was not trivial. You can always recover the sudo command, but, if you changed the permission of all the /usr/ sub-files, since you don't know the exact permission of all the files you changed, you may choose bad/dangerous configuration which would lead you to an unstable system. Maybe doing a re-installation would be better... But if you really want to try to recover your system, or if you didn't recursively changed the /usr permision, you have the following option.
Try #1: Connect as root if the account is enabled (quick to test, but likely to fail)
If you have the root password enabled, you are lucky, just log as root
su root
<enter root password>
chmod 755 /usr
and if all sub files have bad permission (it's may lead to an unstable system) :
chmod -R 755 /usr
Try #2: Boot in recovery mode (do not need USB Key, but likely to fail)
You may want to try to boot in recovery mode, just hit "Escape" or "Shift" when you reboot, and you will get a root. You will be then able to type
chmod 755 /usr
However this method does not always work, depending on how you configured the passwords...
Try #3: Use a LiveUSB (always work)
Take an empty USB key, download a live ubuntu system, copy the system on it by using Unebootin for example, or if you know what you are doing with dd if=<fichier>.iso of=/dev/sdX bs=4M. Boot on the USB key, and then run
sudo mkdir /mnt/drive
sudo mount /sdXn /mnt/drive
cd /mnt/drive
ls # Check that you see usr...
sudo chmod 755 /usr/
- 2,588
