I'm want to install Ubuntu on my computer, but I have some doubts about the installation process.
So I have a 256 GB SSD and a 2 TB HDD. I currently use Windows 10 as my primary OS and it's installed on my SSD in partition C: (it's important to note that my SSD has 3 partitions: a system backup partition, EFI system partition and C: )
Now, I'm forced to install Ubuntu on my HDD (it only has one partition: E:) because my SSD is almost full. Nevertheless, I can create a new partition on my HDD for installing Ubuntu
Is it possible to install Ubuntu on my HDD, which is partitioned as NTFS, and dual boot when I turn on my PC? If so, what's the correct installation process in order to do so?
I'm pretty new to Ubuntu and I would like to learn more
Thank you in advance
Drako
  • 13
Ubuntu on different partition than Windows
It's not possible to install two Operating Systems on one partition. Either you replace it on the partition where you have a different OS by choosing that partition for your install, or you Create a new partition and install the different OS on the new partition.
You mentioned that you know how to create a partition. So perform that step and install the different OS on the partition you create for it.
The Installation
Installing Ubuntu is a very seamless operation. Just boot to the install DVD or the USB installer. You'll be prompted to either Install Ubuntu or Try Ubuntu. Follow the prompts and it'll be installed on your system.
If you already have an Operating System, as in your case, when you run the installer the install options will include install
  1. Alongside the current installed OS. With this option the installer will bring up a slider and allow the user to determine how much space to leave for the current OS and allocate for Ubuntu. With this option you don't have to create a partition. The Installer will split the partition for you, having one for your current OS (Windows) and the other for Ubuntu.
  2. Use the whole Disk for Ubuntu. This option would clearly remove everything currently on the drive and replace it with Ubuntu.
  3. Do Something else. On this choice you will be given an option to select a partition where you want Ubuntu installed. This would be the option you would choose for placing the OS on the new partition you mentioned in your Question that you know how to create.
Note
The installer will clearly notify with a confirmation prompt before making any changes to your system. It'll tell you which changes will be made.
The process is probably easier done than said.
Official Install Steps with pictures:
https://www.ubuntu.com/download/desktop/install-ubuntu-desktop
L. D. James
  • 25,444
