While using apt-get to upgrade my kernel from 3.10 to 4.2 on 14.04 the upgrade stopped after getting an error message. The same error message comes when running:
$ sudo apt-get upgrade
This is the error:
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following package was automatically installed and is no longer required:
busybox-static
Use 'apt-get autoremove' to remove it.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up initramfs-tools (0.103ubuntu4.6) ...
update-initramfs: deferring update (trigger activated)
Processing triggers for initramfs-tools (0.103ubuntu4.6) ...
update-initramfs: Generating /boot/initrd.img-4.2.0-42-generic
Warning: root device  does not exist
Press Ctrl-C to abort build, or Enter to continue
Unsupported platform.
run-parts: /etc/initramfs/post-update.d//flash-kernel exited with return code 1
dpkg: error processing package initramfs-tools (--configure):
 subprocess installed post-installation script returned error exit status 1
 initramfs-tools
Edit: I still have full use of my system and it boots up normally. The problem seems to be with a failed upgrade to 4.2, and now I can't run apt-get upgrade without it telling me that the root device does not exist
Edit: Trying to remove packages:
$ sudo apt-get --purge autoremove
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
$ sudo dpkg --configure -a
update-initramfs: Generating /boot/initrd.img-4.2.0-41-generic
Running:
 $ sudo update-initramfs -c -k 4.2.0-41-generic
boomboomdead
