I'm trying to install Ubuntu 16.04 from a USB drive. I'm using Rufus to create a bootable stick, but everytime I click start, it starts, and then gives the error ISO image extraction failure. What can I do?
What can I do?
- Check the MD5 of your ISO which too few people know you can ACTUALLY do using Rufus! Just click on the
(✓)button next toSELECT(Rufus 3.0 or later) or the#button at the bottom of the Rufus interface (Rufus 2.18 or earlier) after selecting your ISO. There is no need to use another tool. - Run a bad blocks check in Rufus, to make sure that the issue isn't with your flash drive.
- Report that issue in the official issue tracker for Rufus, along with your full log from Rufus, as this is the best place to get help with Rufus issues.
- 1,610
for me the case was that I deleted the rufus_files folder rufus created when it's ran for the very first time. Actually, I keep a different folder for softwares, so i only copied .exe after i did my first iso extraction with rufus and deleted the folder (rufus_files).
so, just reinstall rufus and keep the folder.
peace
- 111
I was trying to create the bootable USB from my office laptop and got in to this issue. I have read many solutions and it didn't work out. From one answer they said it might be due to the anti-virus effect and i tried using my personal laptop and it did work out.
- 133
- 1
- 6
If you are trying to use an ISO located on a network share, copy the file to a local hard drive.
- 111
Mine was failing because my Front USB ports on my case was causing write failures to the thumb drive. Plugged in the back ports and all was good.
In my case, the USB drive was encrypted with BitLocker. I had to remove BitLocker from the drive before it worked. In Windows, just search for BitLocker from the start menu, and see if BitLocker-To-Go is enabled for your drive. Disabling it, then trying Rufus again to write Ubuntu to the drive worked.
I have no idea why, but version 4.2 is giving me this error while 3.14 does not. Try earlier version.
- 101
I know it's been a long time, but I had the same problem. I tried most of the solutions in this thread. Nothing worked.
What ended up solving it was taking the USB out of the USB hub and plugging it directly into the laptop. Hopefully this helps someone...
On Windows install the program PowerISO. Then:
- Open your ISO file.
- Delete
autorun.inf. - Save and exit (overwrite).
Done.
- 119,640
- 1
For me in Windows 10, it seems that MS denies rufus access to items in downloads and desktops, so am unable to actually choose/select the Ubuntu image to send to USB stick.
- 1
Just run rufus as administrator and it works on Windows 10. Otherwise it cannot find the iso file or downloads folder.
