So I think I had problems with Ubuntu in the past installations I've tried, and I had only dedicated the OS a small amount of 10 gigabytes and the swap 8. Now that OS crashed for some reason after installing the "21 Updates" In the software center, I was thinking maybe there isn't enough space for the OS to handle.
so I decided I would change distros from Ubuntu and try out a larger size. I only have around 20 gigabytes to play (approximately 18.9) with though so how much can I dedicate for a comfortable gaming experience? (I want to use it as my day to day OS as well)
I'll try out the answers and if anything goes crashing again I'll ask them here. Thanks in advance!
Klaus
  • 33
For a more or less basic Ubuntu with some main programms always needed about 20GB at least. Ofcourse depends on what you are going to install / update...
derHugo
  • 3,376
  • 34
  • 52
Also consider your swap size - the recommended is about 1.5 x RAM so if you had 4GB of RAM I would suggest using 6GB of swap size as you have limited storage to play with.
XenAinars
  • 19
