I'm running Ubuntu Server 16.04 with Emby using ffmpeg. Just yesterday, I started getting the below error when running sudo apt-get update/upgrade. I'm somewhat new to Linux, but I've tried a huge variety of apt-get autoclean, clean, autoremove, etc. I also found a site that suggested installing jessie-backports and re-installing ffmpeg from there (or something called qtox) but i didn't seem to have any luck with that.
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
 libavcodec57 : Depends: libx265-102 (>= 2.2) but it is not going to be installed
 x265 : Depends: libx265-102 (>= 2.2) but it is not going to be installed
        Depends: libx265-102 (< 2.3) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
I got close to using force-remove-reinstreq on libavcodec57, but I figured I should ask the experts first.
Anyone have any advice on things to try? Emby seems to still be working fine (I've gotten a few video errors but that's probably due to some of my files being messed up, not so much Emby)
Edit: and when I run apt-get -f install, i get the below
Unpacking libx265-102:amd64 (2.2-1~16.04.york0) ...
dpkg: error processing archive /var/cache/apt/archives/libx265-102_2.2-1~16.04.york0_amd64.deb (--unpack):
 trying to overwrite '/usr/lib/x86_64-linux-gnu/libx265.so.102', which is also in package libx265-95:amd64 2.2-0~16.04.york0
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Processing triggers for libc-bin (2.23-0ubuntu5) ...
muru
  • 207,228
I ended up using a combination of answers from two different previous posts to sold my problem. The post that was linked as a duplicate led me to this: trying to overwrite '/usr/bin/opencv_haartraining', which is also in package libopencv2.3-bin 2.3.1+svn6514+branch23-12~oneiric . I was able to use the solution listed by the OP, first running
sudo dpkg -P libx265-95:amd64
then i ran
sudo apt-get -f install
followed by
sudo apt-get update && sudo apt-get upgrade
I got a RAID error upon upgrading about unbootable system, but luckily I have my system booting from my SSD, not my HDD RAID1 array. So I rebooted the server and everything seems to have come back up successfully. Thanks for the help, much love!
