After downloading Master PDF Editor 4 for Linux from the https://code-industry.net website (as a tar.gz) and unarchiving it into /opt, it gives an error when attempting to run it:
./masterpdfeditor4: error while loading shared libraries: libQtSvg.so.4: cannot open shared object file: No such file or directory
How can this be solved?
DavidJ
  • 123
After searching the web, I found how to install the shared library by installing the package libqt4-svg. However, subsequently running masterpdfeditor4 caused the error "Segmentation fault (core dumped)". So, I installed some other KDE dependencies and then it launched fine.
(I just did sudo apt-get install konsole, but there is likely a way to only install the dependencies it actually needs)
The following NEW packages will be installed:
  konsole konsole-kpart kpackagelauncherqml kpackagetool5
  libkf5declarative-data libkf5declarative5 libkf5kirigami2-5
  libkf5newstuff-data libkf5newstuff5 libkf5newstuffcore5
  libkf5notifyconfig-data libkf5notifyconfig5 libkf5package-data
  libkf5package5 libkf5pty-data libkf5pty5 libkf5quickaddons5 libphonon4qt5-4
  libphonon4qt5-data phonon4qt5 phonon4qt5-backend-vlc
  qml-module-org-kde-kirigami2 qml-module-org-kde-kquickcontrolsaddons
  qml-module-org-kde-newstuff qml-module-qtqml-models2
iyrin
  • 1,439
DavidJ
  • 123
