I have Windows 10 and Ubuntu 16.04 LTS installed on my HP Laptop. In Ubuntu the WiFi signal reception is very weak while it is very good in Windows 10.
I have Realtek 8723be Wireless Driver.
I have to use the following code in the terminal window of Ubuntu every time I turn on Ubuntu to make WiFi signal stronger:
sudo modprobe -rv rtl8723be
sudo modprobe -v rtl8723be ant_sel=1
Is there any permanent solution to make the WiFi signal reception stronger on my Ubuntu 16.04 LTS OS ?
pomsky
  • 70,557
Abhirup Banerjee
  • 83
Run in terminal
sudo tee /etc/modprobe.d/rtl8723be.conf <<< "options rtl8723be ant_sel=1"
This will create a config file to make the setting permanent.
Pilot6
  • 92,041
In case anyone comes here from google, as I did. It may help to substitute ant_sel=1 to ant_sel=2.
