I am on a Windows PC and tried connecting to AWS running Ubuntu. I tried opening a file using gedit, was unsuccessful. Someone suggested MobaExtreme. Then I had to install gksudo in the server and tried gedit in the MobaExtreme shell and this solved the problem.
What I am really wondering is:
  1. Why couldn't I open gedit in the first place(This involved discussion about using ssh -X, and something regarding display not set)
  2. What does gksudo establish? (Can you elaborate on 'Owner is not the root'? I have no understanding of this concept).
Edit: Suggested merge answer only part of the question. I can accept the merge but I feel I'll not know other parts which I am curious about!
For point#2:
  1. gksudo is used to pop up the password prompt in a GUI window, no matter whether the application is GUI or CLI.
  2. sudo, asks for the password at the terminal instead of in a GUI window, regardless of the type of application being run.
  3. In scripts that don't run in an interactive terminal, gksu is the easiest way to get a user-entered password straight to sudo.
Nisheet
  • 973
