Here is the output of sudo apt-get install -f mumble
Reading package lists... Done
Building dependency tree
The following information may help resolve the situation:
 mumble : Depends: libavahi-compat-libdnssd1 (>= 0.6.16) but it is not installable
sudo apt-get clean reports no errors. Updates are set to Security, Updates, Backports.
Is there solution to the broken packages error that will allow install of mumble?
