How can I connect to a remote (VNC) Ubuntu Desktop 16.04 with default configuration, but no internet access (i.e. no other way of installing additional software). On my remote machine there are no restrictions to install anything.
The first question was about windows->ubuntu, and there was no solution. I wonder if there would be a way using the same OS? I know the questions seem a bit strange, but there is a serious application background, so plz bear with me and only consider "no way" if you are really sure. Thanks
muru
  • 207,228
CatMan
  • 1,449
  • 19
  • 48
Download the latest OpenSSH for Windows binaries (package OpenSSH-Win32.zip)
Extract the package to a convenient location (we will use C:\openssh in this guide)
As the Administrator, install SSHD and ssh-agent services:
powershell.exe -ExecutionPolicy Bypass -File install-sshd.ps1
Generate server keys by running the following commands from the C:\openssh:
.\ssh-keygen.exe -A
Open a port for the SSH server in Windows Firewall:
    Either run the following PowerShell command (Windows 8 and 2012 or newer only), as the Administrator:
    New-NetFirewallRule -Protocol TCP -LocalPort 22 -Direction Inbound -Action Allow -DisplayName SSH
    or go to Control Panel > System and Security > Windows Firewall > Advanced Settings > Inbound Rules and add a new rule for port 22.
To allow a public key authentication, as an Administrator, from C:\openssh, run:
powershell.exe -ExecutionPolicy Bypass -File install-sshlsa.ps1
and restart the machine
In C:\openssh\sshd_config locate a Subsystem sftp directive and change the path to sftp-server to its Windows location:
Subsystem sftp C:\openssh\sftp-server.exe
Start the service and/or configure automatic start:
    Go to Control Panel > System and Security > Administrative Tools and open Services. Locate SSHD service.
    If you want the server to start automatically when your machine is started: Go to Action > Properties. In the Properties dialog, change Startup type to Automatic and confirm.
    Start the SSHD service by clicking the Start the service.
These instructions are partially based on the official deployment instructions. Setting up SSH public key authentication
Follow a generic guide for Setting up SSH public key authentication in *nix OpenSSH server, with following differences:
Create the .ssh folder (for the authorized_keys file) in your Windows account profile folder (typically in C:\Users\username\.ssh).
Do not change permissions for the .ssh and the authorized_keys.
Connecting to the server
Before the first connection, find out fingerprint of the server’s RSA key by running ssh-keygen.exe -l -f ssh_host_rsa_key -E md5 from the C:\openssh:
C:\openssh>ssh-keygen.exe -l -f ssh_host_rsa_key -E md5 2048 MD5:94:93:fe:cc:c5:7d:d8:2a:33:21:0e:f3:91:11:8a:d9 martin@example (RSA)
Start WinSCP. Login dialog will appear. On the dialog:
Make sure New site node is selected.
On New site node, make sure the SFTP protocol is selected.
Enter your machine/server IP address (or a hostname) into the Host name box.
Enter your Windows account name to the User name box. It might have to be entered in the format user@domain, if running on a domain.
For a public key authentication:
    Press the Advanced button to open Advanced site settings dialog and go to SSH > Authentication page.
    In Private key file box select your private key file.
    Submit Advanced site settings dialog with the OK button.
For a password authentication:
    Enter your Windows account password to the Password box.
    If you Windows account does not have a password, you cannot authenticate with the password authentication (i.e. with an empty password), you need to use the public key authentication.
Save your site settings using the Save button.
Login using Login button.
Verify the host key by comparing fingerprint with the one collected before (see above).
The answer to the question is:
There is no way.
As the first answer suggests there are alternatives when not using the standard install CD or when one is willing to install additional software that is not from the original install media. With google one can find several tutorials how to make a custom Ubuntu install CD. Then, just add the openssh-server package and follow the instructions of the answer of 'Ubuntu user' above.
The only alternative that is close to the question (using original media) would be:
  • Do not install Ubuntu Desktop, install Ubuntu server.
    Although both use the same kernel and are basically the same distributions, the difference between the two official *.iso images is the selection of packages that were put on the CD. The server does have the best remote control package to use: openssh-server.
  • The server can be completed with any desktop to a full desktop version ob Ubuntu.
    The easiest way is to use "tasksel" which is a command line but menu driven installation tool. It offers different Ubuntu flavors to install.
Clearly the disadvantage of that workaround is, that you need to know how to work with the command line in Ubuntu and how things work, e.g. the package management apt and its config file /etc/apt/sources.list.
CatMan
  • 1,449
  • 19
  • 48
