I've got a problem trying to install PHP5.5 (I need such version, because my job requires that) on Ubuntu 12.04 or 16.04 and on others Unix like operating systems such as (Mint, Xubuntu, Lubuntu).
My Ubuntu is absolutely clean, I have just installed it and tried to perform commands as all instructions say:
sudo apt-get install apache2
sudo apt-get install mysql-server mysql-client
sudo add-apt-repository ppa:ondrej/php
sudo apt-get update
sudo apt-get install php5.5
But after the last command I get a conflict (in any Ubuntu like OS - Ubuntu, Xubuntu ...), and I don't know how to solve it:
Unmet dependencies during installing php 5.5 on Ubuntu
I tried to install PHP7.0 first, but that didn't help. Ondrej/php PPA should provide valid version of PHP as I thought, but what to do with that unmet dependencies?
Did anybody try to install PHP 5.5 on Ubuntu and have such conflicts with php-apcu and php-yac?
Or maybe after a New year 2016 PHP5.5 is no more supported by PPA?
muru
  • 207,228
Evgeny Melnikov
  • 109
Follow this step by step:
sudo apt-get install php5 libapache2-mod-php5 php5-mcrypt
Install MySQL
Install MySQL Server
sudo mysql_secure_installation
Use MySQL
mysql -u root -p
Enabling mod_rewrite
sudo a2enmod rewrite
This will activate the module or alert you that the module is already in effect. To put these changes into effect, restart Apache.
sudo service apache2 restart
##curl install##
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install php-curl
Setting Up .htaccess
First, allow changes in the .htaccess file. Open the default Apache configuration file using nano or your favorite text editor.
sudo nano /etc/apache2/sites-enabled/000-default.conf
Or:
/etc/apache2/sites-available$ sudo gedit 000-default.conf
Inside that file, you will find the <VirtualHost *:80> ..`. Inside of line
<Directory /var/www/html>
    Options Indexes FollowSymLinks MultiViews
    AllowOverride All
    Order allow,deny
    allow from all
</Directory>
Restart Apache
sudo apt-get install php-mcrypt
Create the .htaccess file:
sudo nano /var/www/html/.htaccess
To check your hostname run:
hostname
hostname -f
Reference: https://manishpaneri.blogspot.in/2017/01/install-php-on-ubuntu-1604.html
Lorenz Keel
  • 9,511
