I am using Ubuntu 16 and today I have installed the telegram desktop as the following link: Unity Dash and Telegram But I could not run telegram from dash. I also have created the telegram.desktop in following path:
/usr/share/applications/
with following content:
[Desktop Entry]
Version=1.0
Type=Application
Terminal=false
Name=Telegram
Exec=/opt/telegram/Telegram
Comment=Network taking back our right to privacy.
Icon=/opt/telegram/telegram.svg
Categories=GNOME;GTK;Network;
But this does not change any thing.
I can only run telegram by
sudo /opt/telegram/Telegram
but again it does not work without sudo and I got the following error (screenshot): error screenshot
Rasoul
  • 73
It seems at first clean installation of Telegram, you're accidently running it with sudo privilege, and this is where the problem is occurred. You shouldn't have do that, the convenience way to run graphical program as root is using gksudo command.
If you using sudo command on graphical program (such as Telegram), they may save their configuration files in your home directory and caused the file owned by root (inaccessible when you run it with non-root privilege). This is what happen to your /home/rasoul/.local/share/TelegramDesktop/log_startXX.txt.
To resolve this, you may need to reset the file owner and group setting (chown). Open terminal and type:
sudo chown $(id -u):$(id -g) /home/rasoul/.local/share/TelegramDesktop/log_startXX.txt
Source:
What is the difference between "gksudo nautilus" and "sudo nautilus"?
Telegram only runs with sudo
Liso
  • 15,677
Thanks you guys for kind help. Finally, I cam up with solution. First I tried to change the permission of the
but it did not work ( actually I could not change the permission). After that I removed the Telegram Desktop completely, the I removed the following directory:
~/.local/share/TelegramDesktop/log_startXX.txt
by using this command.
sudo rm-R  ~/.local/share/TelegramDesktop
Then, I re-installed the telegram desktop.
Rasoul
  • 73
