This is my gparted image
I want to resize /dev/sda5 to take all of the unallocated space (242.25 GiB). How can I accomplish this?
EDIT 1:
swapon output:
NAME         TYPE       SIZE USED  PRIO
/dev/sda6    partition  14G  0B        -1
sudo blkid | grep swap output
/dev/sda6: UUID="d4ae2fb5-2069-4b6d-b86d-e8c94ebf0fd9
grep swap /etc/fstab output:
# swap was on /dev/sda6 during reparation
UUID=d4ae2fb5-2069-4b6d-b86d-e8c94ebf0fd9 none swap sw 0 0
heynnema
  • 73,649
Warning: FIRST backup all important files on /dev/sda5
To perform the required tasks, you'll need to have a Ubuntu Live DVD for the same version of Ubuntu that you have installed now.
Before (unallocated and sda4/sda5)
After (sda4/sda5 and swap)
In gparted:
  • boot to the Ubuntu Live DVD in Try Ubuntu mode
  • start gparted from the Unity dashboard
  • make sure that you're viewing the proper hard disk... if you only have one hard disk, it's probably /dev/sda
  • make sure it's set to align partitions on MiB boundries
  • note: the following steps may vary slightly and you should stay in contact if there are any difficulties or questions.
  • info: partitions are moved or resized in two different ways. The easy way is to use the graphic representation and use the hand cursor to drag/move partitions, and grab handles on the left/right sides of partitions to resize. The other way is to enter specific numeric values into the space before and space after entry fields. We'll use both methods here.
  • in the lower pane of gparted, right-click on sda4 and select move/resize
  • in the new window that appears, enter a 1 (one) into the space before and the space after numeric fields, then click OK
  • observe the graphic representation in the upper pane, and confirm that sda4 covers the previous unallocated space, and its original location, and that sda5 still only takes up a small portion of the left side sda4
  • if it doesn't appear as instructed, then STOP
  • if it does appear as instructed, click the Apply icon
  • right-click on sda5 and select move/resize
  • in the graphic representation, drag the right side of sda5 to the right, leaving 12-16G free space at the right, then click OK
  • in the bottom pane, right-click on the 12-16G of unallocated space that appears to the right of sda5, and select new logical partition, with a swap file system, sized to consume the entire 12-16G space, then click OK
  • compare the upper pane with the "After" image that I posted earlier, and if they don't look similar (the yellow portion represents swap), then STOP, if they do look similar click the Apply icon
  • note the sda representation of the new swap partition, it'll probably be sda6, you'll need that later when you edit /etc/fstab
In Ubuntu:
  • boot into Ubuntu
In terminal...
  • edit: type sudo mkswap /dev/sda6 changing sda6 to the sdaX number from the previous step, if required
  • type sudo blkid and note the UUID of the new swap partition, and copy it to the clipboard
  • type sudo cp /etc/fstab /etc/fstab.bak # to backup fstab
  • type gksudo gedit /etc/fstab # to edit fstab
  • add the following two lines to the end of fstab, changing the UUID to the one noted above, by pasting the clipboard
# swap was on /dev/sda6 during repartition
UUID=071f8b0e-8e16-4f4d-90ff-a4ae9cc56e2b  none  swap  sw  0  0
  • check your work, save the file, and quit gedit
  • type sudo swapon -a # to enable swap
  • type swapon and verify that it shows memory and swap
  • type reboot
In Windows:
  • boot into Windows
  • open the Power control panel
  • click on change what the power buttons do
  • click on change options that are unavailable
  • uncheck fast start
  • close the Power control panel
  • open an administrative command prompt window
  • type powercfg /h off (turns off hibernation)
  • type chkdsk /f c:
  • approve that chkdsk runs at next boot time
  • reboot Windows
heynnema
  • 73,649
