I can't play any 3d games on Ubuntu 11.10 64 bit because of texture gliches, desktop looks ok but games terrible with Intel HD 3000. Any solution for this? The laptop is HP 4530s. exaple Minecraft problem (but it exist in every game) http://img51.imageshack.us/img51/2629/minecraftproblem.png
This bug is your issue. Buggy intel drivers. There are some very ugly workarounds that I have tried myself that can make the artifacts go away but (in the case of minecraft, at least) do not help the screen flickering.
EDIT: Here's the workaround I crafted up. Firstly, you'll need a newer version of intel-gpu-tools to tweak some data. Go here to pick up a newer version. You may add the PPA but to avoid a lot of unnecessary updates I recommend just manually downloading the package through "View Package Details", then expand the dropdown entry for the oneiric series and download either the AMD64 or i386 package, depending on whether you have 32 or 64 bit. Install the package.
With this installed, you're going to make a crontab. This will run a command AS ROOT on boot. Run the command:
sudo crontab -e
in the terminal. Type in your password. It will ask you which editor to use. Just pick the default (nano). Scroll down to the bottom and on a new line enter the following:
@reboot intel_reg_write 0x9404 0x00001800
To save and exit, press control+x, type y, then press enter. Perform a reboot.
From now on the artifacts should no longer be there.
Iam currently using Ubuntu 12.04 and had the same problem. Here is what i do:
Install mesa 3d graphic library(I think this was the command, correct me if not)
sudo apt-get install libgl1-mesa-glx
Then install this library that lets mesa use texture compression
sudo apt-get install libtxc-dxtn-s2tc0
No extra ppa needed. I test it with Amnesia an Minecraft and both work perfectly.
    - 11
Are you sure is that bug? I believe that you have this issue:
The problem is that when you remove the Nvidia drivers, the files in /usr/lib/xorg/modules/ are removed. But if you reinstall the intel driver it will copy the files back again and everything will be fine! Run these commands in the Terminal:
sudo apt-get remove xserver-xorg-video-intel
sudo apt-get install xserver-xorg-video-intel
Check it out here.
    - 131
