I connect to a Ubuntu host using TeamViewer. It's resolution is currently 800x600. I would like to change it's resolution to 1024x768, but I get this error:
xrandr: Configure crtc 0 failed
The command was:
xrandr --output Virtual1 --mode 1024x768
I've searched for a solution, but I haven't found any.
The result for xrandr --verbose is:
Screen 0: minimum 1 x 1, current 800 x 600, maximum 8192 x 8192
Virtual1 connected primary 800x600+0+0 (0x4f) normal (normal left inverted right x axis y axis) 0mm x 0mm
    Identifier: 0x47
    Timestamp:  351902893
    Subpixel:   horizontal rgb
    Gamma:      1.0:1.0:1.0
    Brightness: 1.0
    Clones:
    CRTC:       0
    CRTCs:      0
    Transform:  1.000000 0.000000 0.000000
                0.000000 1.000000 0.000000
                0.000000 0.000000 1.000000
               filter:
  800x600 (0x4f) 42.750MHz -HSync +VSync *current +preferred
        h: width   800 start  850 end  900 total  950 skew    0 clock  45.00KHz
        v: height  600 start  650 end  700 total  750           clock  60.00Hz
  1360x768 (0x50) 85.500MHz +HSync +VSync
        h: width  1360 start 1424 end 1536 total 1792 skew    0 clock  47.71KHz
        v: height  768 start  771 end  777 total  795           clock  60.02Hz
  1280x800 (0x51) 83.500MHz +HSync -VSync
        h: width  1280 start 1352 end 1480 total 1680 skew    0 clock  49.70KHz
        v: height  800 start  803 end  809 total  831           clock  59.81Hz
  1152x864 (0x52) 108.000MHz +HSync +VSync
        h: width  1152 start 1216 end 1344 total 1600 skew    0 clock  67.50KHz
        v: height  864 start  865 end  868 total  900           clock  75.00Hz
  1280x768 (0x53) 79.500MHz -HSync +VSync
        h: width  1280 start 1344 end 1472 total 1664 skew    0 clock  47.78KHz
        v: height  768 start  771 end  778 total  798           clock  59.87Hz
  1024x768 (0x54) 65.000MHz -HSync -VSync
        h: width  1024 start 1048 end 1184 total 1344 skew    0 clock  48.36KHz
        v: height  768 start  771 end  777 total  806           clock  60.00Hz
  800x600 (0x55) 40.000MHz +HSync +VSync
        h: width   800 start  840 end  968 total 1056 skew    0 clock  37.88KHz
        v: height  600 start  601 end  605 total  628           clock  60.32Hz
  640x480 (0x56) 25.175MHz -HSync -VSync
        h: width   640 start  656 end  752 total  800 skew    0 clock  31.47KHz
        v: height  480 start  489 end  492 total  525           clock  59.94Hz
Virtual2 disconnected (normal left inverted right x axis y axis)
    Identifier: 0x48
    Clones:
    CRTCs:      1
               filter:
Virtual3 disconnected (normal left inverted right x axis y axis)
    Identifier: 0x49
    Clones:
    CRTCs:      2
               filter:
Virtual4 disconnected (normal left inverted right x axis y axis)
    Identifier: 0x4a
    Clones:
    CRTCs:      3
               filter:
Virtual5 disconnected (normal left inverted right x axis y axis)
    Identifier: 0x4b
    Clones:
    CRTCs:      4
               filter:
Virtual6 disconnected (normal left inverted right x axis y axis)
    Identifier: 0x4c
    Clones:
    CRTCs:      5
               filter:
Virtual7 disconnected (normal left inverted right x axis y axis)
    Identifier: 0x4d
    Clones:
    CRTCs:      6
               filter:
Virtual8 disconnected (normal left inverted right x axis y axis)
    Identifier: 0x4e
    Clones:
    CRTCs:      7
               filter:
It seems, that the 1024x768 resolution is supported. Why isn't it available?
I've tried arandr too, but it gives the same error.
The other resolutions are also not working, only 800x600
The result for xtrace xrandr --output Virtual1 --mode 1024x768 is uploaded: http://pastebin.com/AVnbDtQa
If I run xrandr --fb 1024x768 then the it gets pixelerated, and some parts does not fit into the screen.
If I run X -configure I get this error:
(EE)
Fatal server error:
(EE) Server is already active for display 0
    If this server is no longer running, remove /tmp/.X0-lock
    and start again.
(EE)
(EE)
Please consult the The X.Org Foundation support
     at http://wiki.x.org
 for help.
(EE)
I would like to avoid rebooting, if possible.
The result for xrandr -d :0 is:
Virtual1 connected primary 800x600+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
   800x600       60.00*+  60.32
   1360x768      60.02
   1280x800      59.81
   1152x864      75.00
   1280x768      59.87
   1024x768      60.00
   640x480       59.94
Iter Ator
  • 124
