My Thinkpad T61 can only have 4GB RAM, but a program requires at least 4GB memory. I have allocated 16GB swap partition.
When the program starts, it complaints
Insufficient memory allocation. Required is 4000000 KB, but configured is 3979756 KB.
Is there a way to make the O/S consider the swap partition more like real RAM?
Zanna
  • 72,312
Ben Z.
  • 71
Yes, you can. It doesn’t work exactly as RAM does, but it may help you a lot. There’s a parameter called swapiness. This is the measure of how frequently to use your swap space. A higher value means higher access rates. More about setting swappiness can be found on the question How do I configure swappiness?
I think you need a higher swappiness rate. But it would be better to add more memory than to increase your swappiness, as this can cause problems for your hard disk drive.
