I was trying to grant root access to the only user on my machine so I could edit folders and files on the main drive, however it seems I have crashed my system in trying to do so. I used chmod - u on the directory /usr and the GUI started disappearing. I tried rebooting but I can't even load the GUI. Is there an easy way I can fix this without having to reinstall the OS?
Jake
  • 552
Pierson Jarvis
When you start your computer, press Ctrl+Alt+F1. This will switch you to the console. Enter your username and password to continue.
Enter the command:
sudo chmod 755 /usr
You will be prompted for your password, enter it to continue. Then enter sudo reboot to restart the machine. This will restore the permissions of the /usr directory so your system should be back to normal.
Jake
  • 552
