24
I have an animated gif and I'd like to cut off the last 5 seconds. Does anyone know how to do that in Linux/Ubuntu?
Rotareti
  • 569
There are multiple ways to do this.
Option 1: Use a command line tool called gifsicle. It's available in default Ubuntu/Debian repositories.
It's fast and won't affect the quality, buy it only accepts frame numbers, not time, so if you need to cut exact time, you should figure out the frame number yourself. You can view the total number of frames and delay times between each frame with this command:
Then you can divide the time you want to cut with the frame delay and it will give you the number of frames in this time, so you can figure out start frame and end frame.
Replace XXXX with the frame where you want your GIF to start, and YYYY with frame where you want your GIF to end.
Option 2: Using FFMPEG. It's also available in apt.
FFMPEG accepts time directly, so it's very straightforward, but it may worsen the quality of output gif and increase file size in some cases.
ffmpeg -i YOURFILE.gif -ss 00:00:04 -t 00:00:08 -async 1 cut.gif
Option 3: if you're ok with online tools and your GIF does not exceed 20MB, this online tool can cut GIFs by frame number or by time and won't affect the quality.
Maadinsh
  • 636
Here's one more. Using ImageMagick, the command:
You can see how many frames you're starting with using:
The last line of the output will show the number of frames in square brackets, for example:
Long.gif[829] GIF 64x64 64x64+0+0 8-bit sRGB 256c 1.86076MiB 0.031u 0:00.034
which indicates that Long.gif has 830 frames.
Note that much legacy documentation of ImageMagick refers to the identify (now magick identify) and convert (now magick) commands, which could be what you need depending how recent your version is.
