-1
I am a new Ubuntu user. I tried to update my Ubuntu and it showed these errors.
Reading package list... Done
W: http://archive.canonical.com/ubuntu/dists/precise/Release.gpg:
    Signature by key 630239CC130E1A7FD81A27B140976EAF437D05B5 uses weak digest algorithm (SHA1)
W: http://us.archive.ubuntu.com/ubuntu/dists/precise-security/InRelease:
W: http://us.archive.ubuntu.com/ubuntu/dists/precise-updates/InRelease:
W: http://us.archive.ubuntu.com/ubuntu/dists/precise-backports/InRelease:
W: http://us.archive.canonical.com/ubuntu/dists/precise/Release.gpg:
W: The repository 'http://ppa.launchpad.net/tualatrix/ppa/next/ubuntu xenial Release' does not have a Release file.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: GPG error: http://extras.ubuntu.com/ubuntu precise Release:
    The following signatures couldn't be verified because the public key is not available:
    NO_PUBKEY 16126D3A3E5C1192
W: The repository 'http://extras.ubuntu.com/ubuntu precise Release' is not signed.
E: Failed to fetch http://ppa.launchpad.net/tualatrix/ppa/next/ubuntu/dists/xenial/main/source/Sources  404  Not Found
E: Some index files failed to download. They have been ignored, or old ones used instead
How can these be fixed?
Zanna
  • 72,312
Just checked that PPA that's complaining about the "Failed to fetch" error.
From the dist directory of that PPA, it does not have a version for Xenial. So the only solution might be remove that ppa.
If you're upgrading from 12.04 to 16.04, you can try to remove that ppa with: sudo add-apt-repository --remove ppa:tualatrix/next
And update the software list with sudo apt-get update, then you should be able to continue your upgrade task.
Or you can try to upgrade to 14.04, that ppa is available for Trusty.
P.-H. Lin
  • 2,844
  • 19
  • 20
  • execute the below commands one by one..
  • rm -rf /var/lib/apt/lists/*
  • If use using proxy, export the proxy settings by the below commands in terminal with root privilege:
  • export http_proxy=http://proxyaddress:port
  • run the add ppa with sudo environment setting by
  • sudo -E add-apt-repository
Navin a.s
  • 101
