I have this 32Gb micro SD card that was on my android phone. It was working as an external HD.
Now I want to format the SD card to use with another phone, but it seems impossible to format.
I've tried to format without success:
- with the old phone
- with the new phone
- with gparted
- with disks
- with dd command
- manually deleting items with
shift+delete - with windows (because..who knows)
None of this worked. I still have all the files in the SD.
Errors
Gparted:
I see an orange triangle with the exclamation mark:
Fat problem while decoding 2 0
Streamcache allocation problem:: 2
Unable to read the contents of this file system!
Because of this some operations may be unavailable.
The cause might be a missing software package.
The following list of software packages is required for fat32 file system support: dosfstools, mtools.
I have dosfstools and mtools installed.
dd command:
Used the commands
sudo dd if=/dev/zero of=/dev/sdb1 bs=512 count=16
and then
sudo dd if=/dev/zero of=/dev/sdb1 bs=1M
the result were a bunch of similar errors:
Jan 10 00:30:41 asus-ux305fa kernel: [34628.992321] sd 13:0:0:0: [sdb] FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Jan 10 00:30:41 asus-ux305fa kernel: [34628.992331] sd 13:0:0:0: [sdb] Sense Key : Medium Error [current]
Jan 10 00:30:41 asus-ux305fa kernel: [34628.992337] sd 13:0:0:0: [sdb] Add. Sense: Peripheral device write fault
Jan 10 00:30:41 asus-ux305fa kernel: [34628.992344] sd 13:0:0:0: [sdb] CDB: Write(10) 2a 00 00 01 05 28 00 00 f0 00
Jan 10 00:30:41 asus-ux305fa kernel: [34628.992348] blk_update_request: I/O error, dev sdb, sector 66856
Jan 10 00:30:41 asus-ux305fa kernel: [34628.992355] buffer_io_error: 230 callbacks suppressed
Jan 10 00:30:41 asus-ux305fa kernel: [34628.992360] Buffer I/O error on dev sdb1, logical block 64808, lost async page write
Jan 10 00:30:41 asus-ux305fa kernel: [34628.992368] Buffer I/O error on dev sdb1, logical block 64809, lost async page write
Jan 10 00:30:41 asus-ux305fa kernel: [34628.992371] Buffer I/O error on dev sdb1, logical block 64810, lost async page write
Jan 10 00:30:41 asus-ux305fa kernel: [34628.992394] Buffer I/O error on dev sdb1, logical block 64811, lost async page write
Jan 10 00:30:41 asus-ux305fa kernel: [34628.992397] Buffer I/O error on dev sdb1, logical block 64812, lost async page write
Jan 10 00:30:41 asus-ux305fa kernel: [34628.992401] Buffer I/O error on dev sdb1, logical block 64813, lost async page write
Jan 10 00:30:41 asus-ux305fa kernel: [34628.992405] Buffer I/O error on dev sdb1, logical block 64814, lost async page write
Jan 10 00:30:41 asus-ux305fa kernel: [34628.992408] Buffer I/O error on dev sdb1, logical block 64815, lost async page write
Jan 10 00:30:41 asus-ux305fa kernel: [34628.992419] Buffer I/O error on dev sdb1, logical block 64816, lost async page write
Jan 10 00:30:41 asus-ux305fa kernel: [34628.992423] Buffer I/O error on dev sdb1, logical block 64817, lost async page write
with the last one
Jan 10 00:31:36 asus-ux305fa kernel: [34683.849080] usb-storage 1-1:1.0: USB Mass Storage device detected
Jan 10 00:31:36 asus-ux305fa kernel: [34683.849160] scsi host14: usb-storage 1-1:1.0
Jan 10 00:31:37 asus-ux305fa kernel: [34684.847904] scsi 14:0:0:0: Direct-Access Mass Storage Device 1.00 PQ: 0 ANSI: 0 CCS
Jan 10 00:31:37 asus-ux305fa kernel: [34684.848611] sd 14:0:0:0: Attached scsi generic sg1 type 0
Jan 10 00:31:37 asus-ux305fa kernel: [34684.961392] sd 14:0:0:0: [sdb] 61405184 512-byte logical blocks: (31.4 GB/29.2 GiB)
Jan 10 00:31:37 asus-ux305fa kernel: [34684.961692] sd 14:0:0:0: [sdb] Write Protect is off
Jan 10 00:31:37 asus-ux305fa kernel: [34684.961698] sd 14:0:0:0: [sdb] Mode Sense: 03 00 00 00
Jan 10 00:31:37 asus-ux305fa kernel: [34684.961971] sd 14:0:0:0: [sdb] No Caching mode page found
Jan 10 00:31:37 asus-ux305fa kernel: [34684.961978] sd 14:0:0:0: [sdb] Assuming drive cache: write through
Jan 10 00:31:37 asus-ux305fa kernel: [34684.964368] sdb: sdb1
Jan 10 00:31:37 asus-ux305fa kernel: [34684.965321] sd 14:0:0:0: [sdb] Attached SCSI removable disk
Jan 10 00:31:37 asus-ux305fa kernel: [34685.137339] FAT-fs (sdb1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Jan 10 00:32:33 asus-ux305fa kernel: [34740.853595] sd 14:0:0:0: [sdb] FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Jan 10 00:32:33 asus-ux305fa kernel: [34740.853606] sd 14:0:0:0: [sdb] Sense Key : Medium Error [current]
Jan 10 00:32:33 asus-ux305fa kernel: [34740.853611] sd 14:0:0:0: [sdb] Add. Sense: Peripheral device write fault
Jan 10 00:32:33 asus-ux305fa kernel: [34740.853617] sd 14:0:0:0: [sdb] CDB: Write(10) 2a 00 00 00 08 01 00 00 01 00
Jan 10 00:32:33 asus-ux305fa kernel: [34740.853622] blk_update_request: I/O error, dev sdb, sector 2049
Jan 10 00:32:33 asus-ux305fa kernel: [34740.853628] buffer_io_error: 470 callbacks suppressed
Jan 10 00:32:33 asus-ux305fa kernel: [34740.853633] Buffer I/O error on dev sdb1, logical block 1, lost async page write
Why I can't format this SD card?
edit: correct typo in the first command
@roboboykm:
It is a micro SD with no lock. Following the instruction in your comment here the results:
fdisk /dev/sdb
Command (m for help): p
Disk /dev/sdb: 31.4 GB, 31439454208 bytes
256 heads, 63 sectors/track, 3807 cylinders, total 61405184 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x00000000
Device Boot Start End Blocks Id System
/dev/sdb1 * 2048 61405183 30701568 c W95 FAT32 (LBA)
Command (m for help): d
Selected partition 1
Command (m for help): w
The partition table has been altered!
Calling ioctl() to re-read partition table.
WARNING: Re-reading the partition table failed with error 16: Device or resource busy.
The kernel still uses the old table. The new table will be used at
the next reboot or after you run partprobe(8) or kpartx(8)
Syncing disks.
I've tried partprobe but it is not working either. Rebooting the system doesn't help too.
