I have Ubuntu 16.04 lts (rootfs) running on an armhf kernel.
I have an issue when I try to install snaps with errors Unit snap-core-716.mount has failed as per hereunder:
An example of a snap install - no snaps worked so far...
user@hostname:~$ sudo snap install nextcloud [sudo] password for user: error: cannot perform the following tasks: - Mount snap "core" (716) ([start snap-core-716.mount] failed with exit status 1: Job for snap-core-716.mount failed. See "systemctl status snap-core-716.mount" and "journalctl -xe" for details. ) user@hostname:~$
Output of sudo systemctl status snap-core-716.mount
user@hostname:~$ sudo systemctl status snap-core-716.mount
● snap-core-716.mount - Mount unit for core
Loaded: loaded (/etc/systemd/system/snap-core-716.mount; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Mon 2017-01-09 10:48:00 UTC; 1min 53s ago
Where: /snap/core/716
What: /var/lib/snapd/snaps/core_716.snap
Process: 4977 ExecMount=/bin/mount /var/lib/snapd/snaps/core_716.snap /snap/core/716 -t squashfs (code=exited, status=32)
Jan 09 10:48:00 hostname systemd[1]: Mounting Mount unit for core...
Jan 09 10:48:00 hostname mount[4977]: mount: unknown filesystem type 'squashfs'
Jan 09 10:48:00 hostname systemd[1]: snap-core-716.mount: Mount process exited, code=exited status=32
Jan 09 10:48:00 hostname systemd[1]: Failed to mount Mount unit for core.
Jan 09 10:48:00 hostname systemd[1]: snap-core-716.mount: Unit entered failed state.
user@hostname:~$
Output of journalctl -xe
user@hostname:~$ sudo journalctl -xe Jan 09 10:48:00 hostname systemd[1]: snap-core-716.mount: Mount process exited, code=exited status=32 Jan 09 10:48:00 hostname systemd[1]: Failed to mount Mount unit for core. -- Subject: Unit snap-core-716.mount has failed -- Defined-By: systemd -- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel -- -- Unit snap-core-716.mount has failed. -- -- The result is failed. Jan 09 10:48:00 hostname systemd[1]: snap-core-716.mount: Unit entered failed state. Jan 09 10:48:00 hostname /usr/lib/snapd/snapd[2442]: task.go:303: DEBUG: 2017-01-09T10:48:00Z ERROR [start snap-core-716.mount] failed with exit status 1: Job for snap-core-716.mount failed. See "systemctl status snap-core-716.mount" and Jan 09 10:48:01 hostname /usr/lib/snapd/snapd[2442]: taskrunner.go:353: DEBUG: Running task 61 on Undo: Download snap "core" (716) from channel "stable" ........ log file: nap-core-716.mount has failed
How can this be solved?
