My ASUS UX305 boots very slow on ubuntu 16.04, and obviously it is due to bluetooth. Here is the dmesg output :
[ 8.784060] Bluetooth: hci0 command 0xfc8e tx timeout [ 8.784060] Bluetooth: hci0 command 0xfc8e tx timeout [ 8.784115] Bluetooth: hci0 sending frame failed (-19) [ 10.788137] Bluetooth: hci0 command 0xfc11 tx timeout [ 16.780341] Bluetooth: hci0 exiting Intel manufacturer mode failed (-110) [ 96.823524] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
It use to boot very fast and still boots fast on windows.
I tried to rfkill blutooth but did not work
Anyone has a clue what the problem could be ?
Thx
Leoloco
I experienced the same problem (Slow start-up and dmesg's output pointing to Bluetooth for some reason.) after resizing partitions using Gparted on Ubuntu 16.04 to accommodate a dual-boot with Windows 10.
In the process to configure the dual boot the swap partition was deleted and recreated, but the UUID variable on /etc/fstab kept pointing to the deleted partition. Once I fixed this, the start-up time went back to normal.
I found the answer here.
ZKK
  • 46
Ok so I've solved my problem, it was due to a corrupted patition tha the OS was unable to mount and waited 1.5min to boot. The bluetooth seems to start well since then but I don't know why.
Leoloco
