Apparently, Elasticsearch causes my server to crash sometimes.
So I wanted to follow the instructions provided by Binh_Ly here: https://discuss.elastic.co/t/garbage-collection-log-messages-monitor-jvm-duration-2-2m/15673
But he says to change the elasticsearch.yml, which should be in the /etc/elasticsearch folder according to the official elasticsearch website. But neither the file nor the folder do exist and can't even be found when I look for them with find / -name elasticsearch -type d, it only shows me the elasticsearch folder where the data lies, but no other elasticsearch folders.
Would it make sense to just create a new folder? (I'm sorry, I don't have that much experience.)
LizzAlice
  • 127
According to Elasticsearch page setting section, elasticsearch.yml file can be found on ES_HOME/config folder.
elasticsearch configuration files can be found under ES_HOME/configfolder. The folder comes with two files, the elasticsearch.yml for configuring Elasticsearch different modules, and logging.yml for configuring the Elasticsearch logging.
If you have really look anywhere and come on the situation where elasticsearch.yml file missing, then you'll probably interested on creating new one.
Luckily someone has posted content of elasticsearch.yml on GitHub Gist, you may want to look at this elasticsearch.yml - GitHub.
Liso
  • 15,677
Using Ubuntu 20.0.4:
I had the same problem but in my case I did not use sudo at the beginning of search command. I was searching for the file in the /etc folder using the following command: find /etc -type f -iname "elasticsearch*"
I got this:
find: ‘/etc/ssl/private’: Permission denied
find: ‘/etc/elasticsearch’: Permission denied
/etc/default/elasticsearch
find: ‘/etc/polkit-1/localauthority’: Permission denied
find: ‘/etc/cups/ssl’: Permission denied
/etc/init.d/elasticsearch
But I forgot to use sudo, so I was logged in as only a user account without root privileges.
When I tried again as root by putting sudo, I found the file:
sudo find /etc -type f -iname "elasticsearch*"
/etc/elasticsearch/elasticsearch.keystore
/etc/elasticsearch/elasticsearch.yml
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
jason
