I am on Ubuntu 16.04 with the 4.4.0-57 kernel and I want to install a self-made module. The BIOS is a non UEFI BIOS (Kontron 986LCD-M/mITX).
I tried to sign the module by following this procedure but the result of step 3 (sudo mokutil --import MOK.der) is EFI variables are not supported on this system.
I tried to follow this recipe but I cannot find the public keys.
How can I sign a module on a non UEFI board?
Update 1: It seems to be a fairy tale that only modules running with a UEFI Bios have to use signed modules under 16.04:
I use as grub option: `GRUB_CMDLINE_LINUX=" acpi_enforce_resources=lax"`.
I get the error `module verification failed: signature and/or required key missing - tainting kernel` in dmesg if I try to load a module via modprobe.
`sudo mokutil --disable-validation` returns the error `EFI variables are not supported on this system`
================ Update 1 ===================================================
I am sorry but this statement is wrong:
The procedure to which you refer describes disabling Secure Boot validation, not signing modules. There's no need to sign kernel modules on non-UEFI systems, since Secure Boot is exclusively a UEFI feature.
The kernel should work in this way it doesn't. I experiance it because I get always the error message I get the error module verification failed: signature and/or required key missing - tainting kernel in dmesg and the kernel is not loaded.
================ Update 2 =================================================== How can I install shim on a non uefi motherboard:
# aptitude search shim
p grub-splashimages - a collection of great GRUB splashimages
p grub2-splashimages - a collection of great GRUB2 splashimages
p libjs-es5-shim - ECMAScript 5 compat. shims for old JavaScript engines (library
p libjs-es6-shim - ECMAScript 6 compat. shims for legacy JavaScript engines (libr
p node-es5-shim - ECMAScript 5 compat. shims for old JavaScript engines (Node.js
p node-es6-shim - ECMAScript 6 compat. shims for legacy JavaScript engines (Node
p olpc-kbdshim - Dienst zur OLPC-XO-Tastaturunterstützung
v olpc-kbdshim-common -
v olpc-kdbshim-hal -
p ruby-launchy-shim - helper class for launching a web browser
p shimmer-themes - Gtk+ themes from Shimmer Project
p shimmer-wallpapers - Wallpapers from Shimmer Project
p systemd-shim - shim für systemd
p yoshimi - Software-Synthesizer, basiert auf ZynAddSubFX
p yoshimi-data - Voreinstellungen für Yoshimi
Is systemd-shim correct? I believe that it will not work because it is a non-uefi MB...
