Recently got a new laptop and successfully installed Ubuntu on it. However, unlike my other debian laptops, this one seems unable to discover my bluetooth headset.
I tried using bluetoothctl:
power on
agent on
default-agent
scan on
no error messages, but no results came out.
Then I tried hcitool:
hcitool scan
but still came blank.
Blueman also wasn't of much help.
The bluetooth interfaces weren't blocked either, according to rfkill
I noticed that this appeared in my dmesg:
bluetooth hci0: Direct firmware load for brcm/BCM.hcd failed with error -2
Finally, the output of sudo service bluetooth status is
● bluetooth.service - Bluetooth service
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
Active: active (running) since Sat 2017-01-07 15:57:22 GMT; 41min ago
Docs: man:bluetoothd(8)
Main PID: 1015 (bluetoothd)
Status: "Running"
CGroup: /system.slice/bluetooth.service
└─1015 /usr/lib/bluetooth/bluetoothd
Jan 07 16:23:33 towc bluetoothd[1015]: Current Time Service could not be registered
Jan 07 16:23:33 towc bluetoothd[1015]: gatt-time-server: Input/output error (5)
Jan 07 16:23:33 towc bluetoothd[1015]: Not enough free handles to register service
Jan 07 16:23:33 towc bluetoothd[1015]: Sap driver initialization failed.
Jan 07 16:23:33 towc bluetoothd[1015]: sap-server: Operation not permitted (1)
Jan 07 16:23:33 towc bluetoothd[1015]: Failed to get connections: Not Powered (0x0f)
Jan 07 16:23:33 towc bluetoothd[1015]: Endpoint registered: sender=:1.61 path=/MediaEndpoint/A2DPSource
Jan 07 16:23:33 towc bluetoothd[1015]: Endpoint registered: sender=:1.61 path=/MediaEndpoint/A2DPSink
Jan 07 16:23:33 towc bluetoothd[1015]: Failed to set mode: Blocked through rfkill (0x12)
Output of lsusb:
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 005: ID 0930:0225 Toshiba Corp.
Bus 001 Device 003: ID 04f2:b446 Chicony Electronics Co., Ltd
Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
Any suggestions on what to try now?
