I need to install horizon package of openstack cloud software on Ubuntu 16.04.1 LTS on Virtualbox to be able to run Chipster. I have followed the protocols provided by docs.openstack website:
http://docs.openstack.org/developer/horizon/quickstart.html
And everything works fine up until the section:
tox -e runserver
which returns the error:
tox.ConfigError: ConfigError: substitution key 'posargs' not found
The same error occurs just typing tox command.As I searched on the net, this error belong to the version 1.7.0 of Tox and was solved in later versions, The version installed by
sudo apt-get install tox
is 2.3.1-4 and the corrections which were supposed to solve this issue in version 1.7.0 provided here:
https://bitbucket.org/hpk42/tox/pull-requests/85/fix-command-expansion-and-parsing/diff
seems to be already added to the 'tests/test_config.py' and 'tox/_config.py'. I am completely out of ideas. I was wondering if anyone have had the same problem and how it can be solved?
