I am new to Linux (besides briefly messing around with it over 10 years ago) and I have some questions about setting up dual boot with Windows 7. Basically I am looking for the best way to get up and running so if you have other suggestions that would be better than what I list below please let me know!
So my new SSD just came about 5 minutes ago so I'll be installing that today as my boot drive. My "plan" was to install Windows 7 from my USB first and get that all set up and then after all that, partition the SSD and install Ubuntu. Is there any downside to doing it this way? Once Windows is set up do I just use the built in "Disk Management" to partition the drive or when I boot from the Ubuntu installer is there an option there to partition the drive similar to how there is when going through windows setup?
This might not be directly related but is there anything special I need to do to this new SSD before installing windows? It's my first SSD. Should I connect it as a second drive first and use Windows "Disk Management" to format it? OR just install it as my main drive and get right to installing windows? Or should I install it as my second drive and partition it first thing with Disk Management?
As you can see I'm not sure of the best ways to set this all up or if it even really matters. Any input would be appreciated of what is the best way to go about this and why it's better than another way.
Thank you!!
Completely Install windows on the entire drive, don't worry about partitioning at all, use the entire drive, after you have rebooted and installed updates and are happy with the results, you can download a Linux distro such as Ubuntu. Download and burn .iso to blank DVD disk or make a LIVE USB using - unetbootin - Then install Ubuntu using the Live desktop that you boot to. During the install you will have a screen that will ask you if you want to erase disk and install Ubuntu or install Ubuntu alongside Windows. You want to click the check for install alongside Windows. Live desktop installer in Ubuntu will take care of all the partitioning for you :-) All Done ENJOY Using LINUX :-) If you want to check out some COOL Linux distro's go here> http://distrowatch.com/ Go to right side of page and there are listings from the #1 distro to #100 in ranking. ENJOY
