I have a problem with Redshift. It doesn't get the location from my geolocation provider 'geoclue'. The problem was more noticeable when I tried to use Maps app which said I should enable location services in order to be located. I just can't find any settings regarding this. Anyone? Thanks
P.S. Clicking on button "Location Settings" does nothing
Hochopepa
  • 166
From the terminal try:
redshift -l list
You should see: geoclue2
Try changing location provider to geoclue2
If you have redshift config file under ~/.config/redshift.conf this can be changed there.
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
smitha4
  • 41
I use Ubuntu Gnome 16.04 but should work the same:
Settings > Privacy > Location services > on
works for me, although the location accuracy is not perfect!
Zanna
  • 72,312
