I want add different wallpapers in different workspaces but as necessary command line ..
Asked
Active
Viewed 551 times
Set your environment using the excellent linked Q&A
- Install compiz:
sudo apt-get install compiz-fusion-plugins-extra - Remove your desktop icons:
gconftool-2 --set "/apps/nautilus/preferences/show_desktop" --type=boolean "true"
Your wallpapers are defined in the key:
gconftool-2 --get "/apps/compiz/plugins/wallpaper/screen0/options/bg_image"
It takes a comma separated list thus you can set the value using this as an example:
gconftool-2 --set "/apps/compiz/plugins/wallpaper/screen0/options/bg_image" --type=string "[/usr/share/backgrounds/BosqueTK.jpg,/usr/share/backgrounds/BusquedaNocturna.jpg]"
Linked Question:
fossfreedom
- 174,526
