Brand new LINUX user here.
I created a bootable UBUNTU USB drive with 16.04 so that I could boot into a PC with a damaged boot HDD (Windows 10), but fails to boot,to see what files might be recoverable.
I booted successfully off the UBUNTU USB and when I got to the window that looks a lot like File Explorer I saw, 1TB Ext Bay1 (which contains an external HDD that is working), Computer and Gateway (which is my machine).
It appears that Windows 10 is in hibernation mode and I need to get it out of that mode and shut it down completely. I don't seem to be able to do that.
I wanted to see if the files on the C drive were still accessible. When I click on either Gateway or 1TB Ext Bay1, I get a message "Unable to access “Gateway
Error mounting /dev/sda3 at /media/ubuntu/Gateway: Command-line `mount -t "ntfs" -o "uhelper=udisks2,nodev,nosuid,uid=999,gid=999" "/dev/sda3" "/media/ubuntu/Gateway"' exited with non-zero exit status 14: Windows is hibernated, refused to mount.
Failed to mount '/dev/sda3': Operation not permitted
The NTFS partition is in an unsafe state. Please resume and shutdown
Windows fully (no hibernation or fast restarting), or mount the volume
read-only with the 'ro' mount option."
It's the same message when I try this with 1TB Ext Bay1, except that it says 1TB Ext Bay1.
I did try right clicking and selecting Mount, but the same message came up.
Is there a way I can get out of hibernation mode to shut it down completely?
Thanks
Steve
Follow up after trying Sudodus's suggestions:
Thank you for your feedback.
I tried sudo mount /dev/sda3 -o ro rw,users,umask=000 /mnt, went to the file manager, to Computer -> /mnt, but there was nothing there. I then entered the following, but am not sure where to go from here (there's still nothing showing in /mnt).
ubuntu@ubuntu:~$ sudo mount /dev/sda3 -o ro rw,users,umask=000 /mnt
Usage:
 mount [-lhV]
 mount -a [options]
 mount [options] [--source] <source> | [--target] <directory>
 mount [options] <source> <directory>
 mount <operation> <mountpoint> [<target>]
Mount a filesystem.
Options:
 -a, --all               mount all filesystems mentioned in fstab
 -c, --no-canonicalize   don't canonicalize paths
 -f, --fake              dry run; skip the mount(2) syscall
 -F, --fork              fork off for each device (use with -a)
 -T, --fstab <path>      alternative file to /etc/fstab
 -i, --internal-only     don't call the mount.<type> helpers
 -l, --show-labels       show also filesystem labels
 -n, --no-mtab           don't write to /etc/mtab
 -o, --options <list>    comma-separated list of mount options
 -O, --test-opts <list>  limit the set of filesystems (use with -a)
 -r, --read-only         mount the filesystem read-only (same as -o ro)
 -t, --types <list>      limit the set of filesystem types
     --source <src>      explicitly specifies source (path, label, uuid)
     --target <target>   explicitly specifies mountpoint
 -v, --verbose           say what is being done
 -w, --rw, --read-write  mount the filesystem read-write (default)
 -h, --help     display this help and exit
 -V, --version  output version information and exit
Source:
 -L, --label <label>     synonym for LABEL=<label>
 -U, --uuid <uuid>       synonym for UUID=<uuid>
 LABEL=<label>           specifies device by filesystem label
 UUID=<uuid>             specifies device by filesystem UUID
 PARTLABEL=<label>       specifies device by partition label
 PARTUUID=<uuid>         specifies device by partition UUID
 <device>                specifies device by path
 <directory>             mountpoint for bind mounts (see --bind/rbind)
 <file>                  regular file for loopdev setup
Operations:
 -B, --bind              mount a subtree somewhere else (same as -o bind)
 -M, --move              move a subtree to some other place
 -R, --rbind             mount a subtree and all submounts somewhere else
 --make-shared           mark a subtree as shared
 --make-slave            mark a subtree as slave
 --make-private          mark a subtree as private
 --make-unbindable       mark a subtree as unbindable
 --make-rshared          recursively mark a whole subtree as shared
 --make-rslave           recursively mark a whole subtree as slave
 --make-rprivate         recursively mark a whole subtree as private
 --make-runbindable      recursively mark a whole subtree as unbindable
For more details see mount(8).
ubuntu@ubuntu:~$ sudo parted -ls
Model: ATA ST31500341AS (scsi)
Disk /dev/sda: 1500GB
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Disk Flags:
Number  Start   End     Size    Type     File system  Flags
 1      1049kB  17.2GB  17.2GB  primary  ntfs         diag
 2      17.2GB  17.3GB  105MB   primary  ntfs         boot
 3      17.3GB  1500GB  1483GB  primary  ntfs
Model:  USB FLASH DRIVE (scsi)
Disk /dev/sdb: 4010MB
Disk Flags:
 1      16.4kB  4010MB  4010MB  primary  fat32        boot
Model: ATA SAMSUNG HD103UJ (scsi)
Disk /dev/sdc: 1000GB
Disk Flags:
 1      32.3kB  1000GB  1000GB  primary  ntfs
ubuntu@ubuntu:~$ sudo umount /mnt
umount: /mnt: not mounted
Usage:
 mount [-lhV]
 mount -a [options]
Mount a filesystem.
Options:
Source:
Operations:
Do what the automatic tip suggests: mount the partition /dev/sda3 read-only with the 'ro' mount option. Start a terminal window with the hotkey combination
ctrl + alt + t
You can use the standard mount point /mnt according to this command line in the terminal window.
sudo mount /dev/sda3 -o ro,users,umask=000 /mnt
After that you should be able to read and copy the files in /dev/sda3 with command line tools or with the file manager, 'the window that looks a lot like File Explorer'. Select 'Computer' in the left pane, then browse to the directory '/mnt', and there you should file Windows files.
-o-
If /dev/sda3 is not the main Windows directory you can get help from the output of the following command (in the terminal window)
sudo parted -ls
where you see the partition numbers and what kind of partition they are.
sudo umount /mnt
sudo mount /dev/sdxn -o ro,users,umask=000 /mnt
where x is the drive letter and n is the number of the partition, for example 1, 2 or 3, that you think is the correct one, the main Windows partition C:
sudodus
  • 47,684
