I have a Lenovo V110 running on Ubuntu 16.04
The WIFI was working perfectly until a few days ago. Suddenly a specific WIFI which use to work before has stopped working. Other Wifi work fine in my laptop and this particular wifi works on other laptops but just not on my laptpo.
After a lot of debugging I came across this question so I followed these commands to get this -
Command
lspci -nnk | grep -iA2 net; dmesg | grep ath10k
Output
02:00.0 Network controller [0280]: Qualcomm Atheros Device [168c:0042] (rev 30)
Subsystem: Lenovo Device [17aa:4035]
Kernel driver in use: ath10k_pci
03:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 15)
Subsystem: Lenovo RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [17aa:3841]
Kernel driver in use: r8169
Kernel modules: r8169
[ 12.056523] ath10k_pci 0000:02:00.0: pci irq msi interrupts 1 irq_mode 0 reset_mode 0
[ 13.066565] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/cal-pci-0000:02:00.0.bin failed with error -2
[ 15.031654] ath10k_pci 0000:02:00.0: qca9377 hw1.0 (0x05020000, 0x003820ff sub 17aa:4035) fw WLAN.TF.1.0-00267-1 fwapi 5 bdapi 2 htt-ver 3.1 wmi-op 4 htt-op 3 cal otp max-sta 32 raw 0 hwcrypto 1 features ignore-otp
[ 15.031657] ath10k_pci 0000:02:00.0: debug 0 debugfs 1 tracing 1 dfs 0 testmode 0
[ 15.263541] ath10k_pci 0000:02:00.0 wlp2s0: renamed from wlan0
The stack trace above has this error line -
Other useful info -
Command
uname -r
Output
4.4.0-57-generic
Command
sudo lshw -C network
Output
*-network DISABLED
description: Wireless interface
product: Qualcomm Atheros
vendor: Qualcomm Atheros
physical id: 0
bus info: pci@0000:02:00.0
logical name: wlp2s0
version: 30
serial: cc:b0:da:a6:8c:0d
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=ath10k_pci driverversion=4.4.0-57-generic firmware=WLAN.TF.1.0-00267-1 latency=0 link=no multicast=yes wireless=IEEE 802.11abgn
resources: irq:280 memory:d1000000-d11fffff
*-network
description: Ethernet interface
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:03:00.0
logical name: enp3s0
version: 15
serial: 54:ee:75:ab:02:4a
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl8168h-2_0.0.2 02/26/15 ip=192.168.20.128 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
resources: irq:277 ioport:d000(size=256) memory:d1204000-d1204fff memory:d1200000-d1203fff
Command
rfkill list all
Output
0: ideapad_wlan: Wireless LAN
Soft blocked: no
Hard blocked: no
1: ideapad_bluetooth: Bluetooth
Soft blocked: yes
Hard blocked: no
2: hci0: Bluetooth
Soft blocked: yes
Hard blocked: no
3: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
Command
ifdown wlp2s0
Output
Unknown interface wlp2s0
Command
sudo vim /etc/network/interfaces
Output
# interfaces(5) file used by ifup(8) and ifdown(8)
auto lo
iface lo inet loopback
Some other things I've noticed while connected to that specific Wifi which is not working are -
- I'm able to get an IP address.
- I'm able to ping that IP address.
- I'm not able to ping the default gateway found using
routescommand. - I'm not able to ping any external address.
Any help would be appreciated.
EDIT Still experiencing these problems with some other WiFi as well. Still no solution found.
