I'm trying to install Clockwordmod Tether on my Ubuntu 16.10 laptop in order to facilitate USB tethering with the corresponding app on Google Play.
I've downloaded and extracted the Tether tar file. The instructions for installation are very simple. Just run the following in a terminal:
cd /home/username/Tether/node
./configure
make
But when I run make, it always ends in this error:
../deps/v8/src/checks.h:251:22: warning: typedef ‘__StaticAssertTypedef__125’ locally defined but not used [-Wunused-local-typedefs]
SEMI_STATIC_JOIN(__StaticAssertTypedef__, __LINE__)
../deps/v8/src/checks.h:241:39: note: in definition of macro ‘SEMI_STATIC_JOIN_HELPER’
#define SEMI_STATIC_JOIN_HELPER(a, b) a##b
../deps/v8/src/checks.h:251:5: note: in expansion of macro ‘SEMI_STATIC_JOIN’
../deps/v8/src/checks.h:283:30: note: in expansion of macro ‘STATIC_CHECK’
#define STATIC_ASSERT(test) STATIC_CHECK(test)
../deps/v8/src/v8utils.h:125:3: note: in expansion of macro ‘STATIC_ASSERT’
STATIC_ASSERT(sizeof(T) == kPointerSize);
In file included from ../deps/v8/src/elements.h:32:0,
from ../deps/v8/src/objects-inl.h:38,
from ../deps/v8/src/v8.h:60,
from ../deps/v8/src/accessors.cc:28:
../deps/v8/src/objects.h: At global scope:
../deps/v8/src/objects.h:5017:44: error: left operand of shift expression ‘(-1 << 3)’ is negative [-fpermissive]
static const int kElementsKindMask = (-1 << kElementsKindShift) &
../deps/v8/src/objects.h:7152:36: error: left operand of shift expression ‘(-8 << 26)’ is negative [-fpermissive]
(~kMaxCachedArrayIndexLength << kArrayIndexHashLengthShift) |
deps/v8/tools/gyp/v8_base.target.mk:209: recipe for target '/home/username/Tether/node/out/Release/obj.target/v8_base/deps/v8/src/accessors.o' failed
make[1]: *** [/home/username/Tether/node/out/Release/obj.target/v8_base/deps/v8/src/accessors.o] Error 1
make[1]: Leaving directory '/home/username/Tether/node/out'
Makefile:26: recipe for target 'node' failed
make: *** [node] Error 2
Looking on the net, it was suggested to install the following:
sudo apt-get install libssl-dev cmake g++ lib32ncurses5 nodejs-legacy
But this didn't help. I also saw that it might have something to do with a Python version issue, but I could not find user level instructions on how to deal with that.
Is there a way I can resolve this and install Tether on my Ubuntu laptop? And is the solution something that can be explained in terms that someone who knows nothing about configure or make can understand?
Update:
Thanks to DropHammer99's answer below, it seems I was able to successfully compile the program. This is how the XXFLAGS=-fpermissive make command ended after a few minutes:
LINK(target) /home/username/Tether/node/out/Release/node: Finished
touch /home/username/Tether/node/out/Release/obj.target/node_dtrace_header.stamp
touch /home/username/Tether/node/out/Release/obj.target/node_dtrace_provider.stamp
touch /home/username/Tether/node/out/Release/obj.target/node_dtrace_ustack.stamp
touch /home/username/Tether/node/out/Release/obj.target/node_etw.stamp
ln -fs out/Release/node node
Unfortunately, though, when I first ran the program as instructed in the README file, it crashed with this error:
~/Tether$ sudo linux/run.sh
[sudo] password for username:
~/Tether
Starting Tether...
* daemon not running. starting it now on port 5037 *
* daemon started successfully *
linux/run.sh: line 39: 21096 Segmentation fault (core dumped) $NODE/node tether.js
Is this program just not going to work, or is there something I can do to resolve this segmentation fault error?
