I am trying to install/update things ( php7.0-soap for example) but this message keep appearing.
     libnginx-mod-http-auth-pam : Depends: nginx-common (= 1.10.1-3+xenial2) but 1.10.1-0+xenial0 is to be installed
     libnginx-mod-http-echo : Depends: nginx-common (= 1.10.1-3+xenial2) but 1.10.1-0+xenial0 is to be installed
     libnginx-mod-http-geoip : Depends: nginx-common (= 1.10.1-3+xenial2) but 1.10.1-0+xenial0 is to be installed
     libnginx-mod-http-image-filter : Depends: nginx-common (= 1.10.1-3+xenial2) but 1.10.1-0+xenial0 is to be installed
     libnginx-mod-http-subs-filter : Depends: nginx-common (= 1.10.1-3+xenial2) but 1.10.1-0+xenial0 is to be installed
     libnginx-mod-http-upstream-fair : Depends: nginx-common (= 1.10.1-3+xenial2) but 1.10.1-0+xenial0 is to be installed
     libnginx-mod-http-xslt-filter : Depends: nginx-common (= 1.10.1-3+xenial2) but 1.10.1-0+xenial0 is to be installed
     libnginx-mod-mail : Depends: nginx-common (= 1.10.1-3+xenial2) but 1.10.1-0+xenial0 is to be installed
     libnginx-mod-stream : Depends: nginx-common (= 1.10.1-3+xenial2) but 1.10.1-0+xenial0 is to be installed
apt-update is also blocked by this one. For now I really need soap, in the future maybe more things. Is there a way to fix this without (or with minimum) impact on the running nginx server, which is usually serving 300-600 users at a time.
We are using : Ubuntu 16.04.1 LTS
    lsb_release -a
    No LSB modules are available.
    Distributor ID: Ubuntu
    Description:    Ubuntu 16.04.1 LTS
    Release:        16.04
    Codename:       xenial
UPDATE Jan 1st 2017:
Using -f in "apt-get dist-upgrade" or "apt-get install" as suggested by @Thomas Ward did make some progress. But I am stuck at :
    Unpacking nginx-common (1.10.1-3+xenial2) over (1.10.1-0+xenial0) ...
    dpkg: error processing archive /var/cache/apt/archives/nginx-common_1.10.1-3+xen                                 ial2_all.deb (--unpack):
     trying to overwrite '/etc/logrotate.d/nginx', which is also in package nginx 1.                                 11.3-1~xenial
    Preparing to unpack .../nginx-full_1.10.1-3+xenial2_amd64.deb ...
    Unpacking nginx-full (1.10.1-3+xenial2) over (1.10.1-0+xenial0) ...
    dpkg: error processing archive /var/cache/apt/archives/nginx-full_1.10.1-3+xenia                                 l2_amd64.deb (--unpack):
     trying to overwrite '/usr/sbin/nginx', which is also in package nginx 1.11.3-1~                                 xenial
    dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
    Preparing to unpack .../init-system-helpers_1.29ubuntu4_all.deb ...
    Unpacking init-system-helpers (1.29ubuntu4) over (1.29ubuntu3) ...
    Processing triggers for man-db (2.7.5-1) ...
     /var/cache/apt/archives/nginx-common_1.10.1-3+xenial2_all.deb
     /var/cache/apt/archives/nginx-full_1.10.1-3+xenial2_amd64.deb
I understand what it is saying but have no clue what to do..
I ended up purge those libnginx-mod-... then purged nginxfull and nginx-common.
Then "dpkg -i --force-overwrite" any file that is in the way. Finally restore nginx config files in /etc/nginx (which I backed up earlier of course).
The server was down for like 5-10 mins... but things are done. Thanks Thomas for helping out
