I have tried everything. Making a Live USB, opening up the PC so I can manually load the ISO files into it and boot from there, Unplugging the USB at various times, but Ubuntu is not installing.
The one time it seemed to be working (it got onto the "installation in progress" page,) the progress bar was not moving. The Terminal said "unable to remove directory" or "unable to connect to server" or things like that.
PC specs:
  • Quad core processor @ 2.4 GHZ
  • 12 GB RAM
  • 1 TB 7200 RPM Hard Drive
  • UEFI boot
  • 3x USB ports
  • 1080p display
  • Graphics: Intel Haswell Mobile
UPDATE:
I have gotten it to the choose timezone part, and the installation gets locked up on the "force uefi installation?" popup.
Zanna
  • 72,312
E.T.
  • 99
Go into your BIOS/firmware setup when the computer first boots and change the boot type to "legacy" if you aren't worried about using UEFI/EFI boot.
This should get you up and running again.
Personally, I prefer UEFI/EFI but it's not absolutely necessary. Just use legacy mode (sometimes called compatibility mode).
FINALLY GOT IT TO WORK!!! Apparently I was using the wrong USB port (go figure!)
E.T.
  • 99
