I have install php5-interbase but when I see into my phpinfo();, there is no inter base extension.
Please help me.
Please help me.
Thank you for @strom that trying to help me about the issue.
Finally i got the answer. Here it is :
Try this:
sudo updatedb
locate interbase.ini
Should show it located at /etc/php5/mods-available
locate interbase.so
Edit interbase.ini and change extension to match the path to mcrypt.so, example:
extension=/usr/lib/php5/20121212/interbase.so
Now this:
Verify that new files exists here (they should be auto created from the issue above)
ls -al /etc/php5/cli/conf.d/20-interbase.ini
ls -al /etc/php5/apache2/conf.d/20-interbase.ini
Otherwise do the following
Create symbol links now
sudo ln -s /etc/php5/mods-available/interbase.ini /etc/php5/cli/conf.d/20-interbase.ini
sudo ln -s /etc/php5/mods-available/interbase.ini /etc/php5/apache2/conf.d/20-interbase.ini
Restart Apache
sudo service apache2 restart
i found this solution in : Mcrypt extension is missing in 14.04 server for mysql
