I am using Cinnamon 2.8.6 and ubuntu 16.04. I need to set specific image as desktop background. However after google search, I got solution with following commands:
gsettings set org.gnome.desktop.background show-desktop-icons false
gsettings set org.gnome.desktop.background picture-uri file:///home/techy/Downloads/desktop_bg.jpg
gsettings set org.gnome.desktop.background show-desktop-icons true
After this, background is changed. But I am not able to understand which package is responsible to execute this change ? How the script is actually working ? Is there any other way to do it from terminal ?
d a i s y
  • 5,551
techy
  • 127
To understand what these commands do let's follow the thread.
  1. man gsettings says
    GSettings configuration tool
    but what is "GSettings"?
  2. On https://wiki.gnome.org/HowDoI/GSettings I found:
    GSettings are a nice way to manage your application’s settings.
    Ok, that's a little better because it describes the high-level purpose but it's still very vague.
  3. Let's go back to man gsettings. The usage of the gsettings set command is described like this:
    gsettings set SCHEMA [:PATH] KEY VALUE
    So GSettings appears to be some kind of key-value store with hierarchical key schemata.
    To summarize, the command
    will assign the value file:///home/techy/Downloads/desktop_bg.jpg to the key picture-uri belonging to the schema org.gnome.desktop.background.
  4. Now what happens when that value is (re-)assigned? Here's another gsettings command:
    monitor SCHEMA [:PATH] [KEY]
    Monitors KEY for changes and prints the changed values. If no KEY is specified, all keys in the schema are monitored. Monitoring will continue until the process is terminated.
    So applications can monitor schemata and keys for changes.
    Apparently the process responsible for drawing the desktop background wallpaper monitors this key and reacts to changes by drawing the image in the file referenced in the picture-uri value. Usually the desktop compositor of your desktop environment is responsible for that. In your case that would be Cinnamon but other people might have Gnome Shell or MATE or Unity.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
