I have understood that is impossible to use dd or cat for copy all data of a partition to another partition with differences in sizes, Is this statement correct?, example
2 HDD, the first /dev/sdd1 (100gb), and used 30gb and the second /dev/sdc1 (50gb), and haven't data
Surely I cant use:
cat /dev/sdd1 >/dev/sdc1
why? Because sdd1 has partition of 100gb and sdc1 has limit of 50gb
Is it true? what should I use for copying?
could I use (Assuming that hdds are mounted):
cp -avr /mnt/sdd1/* /mnt/sdc1/
Is it correct to use cp? someone know to alternative to cp
EDIT: In case of cant mount hdd because linux not recognized partition, what could I do? Continue with this new question in: "Backup without free space in not recognized partition"
Note: I don't talking about of recovery tools like ddrescue
Thank you very much.
Milor123
  • 231
Sure, cp will work fine. You might have to use shopt -s dotglob so that * matches files and folders whose names begin with .:
shopt -s dotglob
There's also rsync:
rsync -a --info=progress2 /mnt/sdd1/ /mnt/sdc1/
It has a nicer progress display.
muru
  • 207,228
Please notice the difference of copying at the file level and cloning partitions or whole drives at the device level.
Copy files as described by muru
In this case you use the mounted partitions, where you see the directories and files.
rsync is a very good tool for backup and synchronizing.
Clone devices as described below
Cloning devices is very risky, and you must check and double-check, that you write to the correct device. Otherwise you might overwrite your family pictures ... and it is only a minor typing error away. When cloning you should unmount all partitions on the source and target devices. You already noticed that you should clone to a device of at least the same same.
sudo dd if=/dev/sdx of=/dev/sdy bs=4096
clones a device for example USB pendrive (from drive x to drive y).
sudo dd if=/dev/sdxm of=/dev/sdyn bs=4096
clones a partition to another partition (from partition xm to partition yn, where x and y are drive letters and m and n are partition numbers).
sudo dd if=/dev/sdx of=file.img bs=4096
creates an image file of a drive.
sudo dd if=/dev/sdx bs=4096 | xz > file.img.xz
creates a compressed image file.
sudo if=ubuntu.iso of=/dev/sdx bs=4096
creates a USB boot drive from an Ubuntu iso file.
-o-
It is possible to clone with cp instead of dd and get similar results.
Tools
In order to reduce the risk and to make the process easier for you, there are tools to help with this process, particularly to create boot drives from iso files and [compressed] image filas. Examples: the Ubuntu Startup Disk Creator (in 16.04 LTS and newer), Disks (gnome-disks), mkusb.
Clonezilla is a tools that can select the used blocks on the 'drive surface' and copy/clone them, while it skips the unused blocks. This makes cloning with Clonezilla much faster than cloning with dd (or cp), particularly, in a drive with a lot of free space.
sudodus
  • 47,684
Firstly, the short version is no, and the reason being, you do not know where your data is on your first drive. It is almost certain that your data will not be in the first 30GB. This is something built into the linux filesystem, and the reason you never need to defrag; ie. your data is randomly allocated into the free space, the opposite of your old MSDOS days of having to defrag once a week.
I don't have the reputation points to adjust the one commend above, but your quickest way of achieving what you need is this:
rsync -avz --delete /mnt/sdd1 /mnt/sdc1
The -r is not necessary, as -a automatically implies -r too. I have included descriptions of the switches:
-a, --archive archive mode; equals -rlptgoD (no -H,-A,-X)
--delete delete extraneous files from destination dirs
-z, --compress compress file data during the transfer
You may choose to neglect -z, however I find it very handy for network copies, especially Wi-Fi.
For the repair, have you tried fsck?
I found another tool called TestDisk from http://www.cgsecurity.org/, but you're required to have at least that amount of space available that you're wanting to recover.
wjandrea
  • 14,504
