I realise that similar questions have been asked before in multiple posts. Some are linked at the end of this question. But my situation is a little different and I couldn't find any post addressing this.
I have created a Live USB Ubuntu 16.10 Desktop, with persistent storage. I have successfully booted into it and installed software such as Chrome, Eclipse and done an apt-get upgrade. These changes have persisted across reboots previously.
Now I am trying to boot the same USB Key on the same USB port of the same laptop. But I am getting the error:
(initramfs) unable to find a medium containing a live file system
It seems that the upgrade / software installation process has brought this error on. Has anyone seen such behaviour before? Any tips?
I have tried booting into the laptop and also into VMWare player using Plop Boot Manager. Same error.
I have already seen the below posts and tried their suggestions with no luck:
Thanks in advance for your help.
Vipul Swarup
  • 111
This sounds like the casper-rw persistence file has been filled and has no more space left.
It is generally recommended not to do an update on a persistent usb drive as this quickly fills the casper-rw file which is limited to 4GB in size.
It is not possible to easily do an upgrade to a Persistent or Live drive as the kernel is part of a read only squashFS file.
To confirm if this is the problem try temporarily renaming the casper-rw file and rebooting.
You can also mount and access the casper-rw file thus:
mkdir /tmp/casper
sudo mount -o loop /path/to/casper-rw /tmp/casper
If you are using a casper-rw persistent partition, it can be accessed from a second Live USB or Live DVD.
Automatic updates should be turned off with persistent drives.
Edit: If the drive was made using mkusb there is probably a NTFS partition named usbdata.
If this partition gets fragmented, as NTFS partitions sometimes do, you can get the same error message. Try backing up and reformatting this partition.
There is a chance that this partition can be defragged in Windows 10. I prefer not to mess with multi partition flash drives in Windows.
Fragmenting can be a sign that the drive was unplugged while being written to, don't do that.
C.S.Cameron
  • 20,530
  • 78
  • 125
what i did:
create lubuntu 17.04 live usb with unetbootin (with 8gb persistence).
then boot usb and do: sudo apt upgrade
after upgrade powerdown and mount usb and copy:
/casper/vmlinuz.efi to /casper/vmlinuz.efi.old
and rename /casper/vmlinuz to /casper/vmlinuz.efi
boot usb again and all will be fine
gilux
