I installed the latest driver 375.26 for the NVIDIA GTX 1060 GPU using the following commands:
sudo add-apt-repository ppa:graphics-drivers/ppa
sudo apt update
sudo apt install nvidia-375
This operation seems to have installed the 367.57 and 370.28 drivers additionally.
drivers
How can I remove the 367 and 370 drivers?
cl-netbox
  • 31,491
wigging
  • 173
This is meant to be general information for you and all the other users reading your question. There are several different graphics drivers available in the Ubuntu repositories - BUT ... there is only one single graphics driver installed and in use when the Ubuntu operating system boots !
So when you install the NVIDIA drivers 375.26 and had, let's say the drivers 367 installed before, the old drivers automatically are getting uninstalled and the new drivers - in your case 375 - are getting installed and are active after rebooting the operating system. To check which drivers are installed, execute the following command : dpkg --get-selections | grep nvidia. Example :
nvidia-375                  install
nvidia-opencl-icd-375       install
nvidia-prime                install
nvidia-settings             install
Of course you can alternatively remove the old drivers manually before installing new drivers.
The command to remove the currently installed drivers would be : sudo apt purge nvidia*
Zanna
  • 72,312
cl-netbox
  • 31,491
