I have been using Déjà Dup to create backups for several years. Recently it started to fail with the message
Permission denied when trying to read ‘/duplicity-inc.20161201T072516Z.to.20161202T074205Z.manifest.gpg’.
This seems to happen after the program has written backup files to the very same directory. The ownership of the file and the containing directory seem right:
drwxr-xr-x 2 myuser myuser 68K Dec  2 08:47 dejadup-backup/
-rw-r--r-- 1 myuser myuser 13K Dec  2 08:47 dejadup-backup/duplicity-inc.20161201T072516Z.to.20161202T074205Z.manifest.gpg
The target directory is on a remote server mounted via davfs2. My /etc/fstab looks like this:
$ cat /etc/fstab
# mount the fileserver
https://fileserver.domain /mnt/fileserver davfs user,_netdev,auto,uid=myuser,gid=myuser 0 0
Any ideas what might cause this and how I can fix it?
Fabby
  • 35,017
jotrocken
  • 352
For those coming here from a search, I had a similar error, and the problem was that I put / before and after the backup folder name...
Andrew
  • 200
After debugging was turned on using DEJA_DUP_DEBUG=1 deja-dup --backup > dejadup.log 2>&1, your dejadup.log file contains:
DUPLICITY: ERROR 30 EOFError
DUPLICITY: . Traceback (most recent call last):
DUPLICITY: .   File "/usr/bin/duplicity", line 1532, in <module>
DUPLICITY: .     with_tempdir(main)
DUPLICITY: .   File "/usr/bin/duplicity", line 1526, in with_tempdir
DUPLICITY: .     fn()
DUPLICITY: .   File "/usr/bin/duplicity", line 1380, in main
DUPLICITY: .     do_backup(action)
DUPLICITY: .   File "/usr/bin/duplicity", line 1454, in do_backup
DUPLICITY: .     globals.gpg_profile.passphrase = get_passphrase(1, action)
DUPLICITY: .   File "/usr/bin/duplicity", line 198, in get_passphrase
DUPLICITY: .     pass1 = getpass_safe(_("GnuPG passphrase for decryption:") + " ")
DUPLICITY: .   File "/usr/bin/duplicity", line 93, in getpass_safe
DUPLICITY: .     return getpass.getpass(message)
DUPLICITY: .   File "/usr/lib/python2.7/getpass.py", line 83, in unix_getpass
DUPLICITY: .     passwd = fallback_getpass(prompt, stream)
DUPLICITY: .   File "/usr/lib/python2.7/getpass.py", line 118, in fallback_getpass
DUPLICITY: .     return _raw_input(prompt, stream)
DUPLICITY: .   File "/usr/lib/python2.7/getpass.py", line 135, in _raw_input
DUPLICITY: .     raise EOFError
DUPLICITY: . EOFError
DUPLICITY: .
and a bit further:
DUPLICITY: DEBUG 1
DUPLICITY: . Backtrace of previous error: Traceback (innermost last):
DUPLICITY: .   File "/usr/lib/python2.7/dist-packages/duplicity/backend.py", line 365, in inner_retry
DUPLICITY: .     return fn(self, *args)
DUPLICITY: .   File "/usr/lib/python2.7/dist-packages/duplicity/backend.py", line 563, in get
DUPLICITY: .     self.backend._get(remote_filename, local_path)
DUPLICITY: .   File "/usr/lib/python2.7/dist-packages/duplicity/backends/giobackend.py", line 146, in _get
DUPLICITY: .     self.__copy_file(source_file, target_file)
DUPLICITY: .   File "/usr/lib/python2.7/dist-packages/duplicity/backends/giobackend.py", line 119, in __copy_file
DUPLICITY: .     None, self.__copy_progress, None)
DUPLICITY: .  Error: g-io-error-quark: Error opening file: Operation not permitted (14)
DUPLICITY: .
DUPLICITY: WARNING 1
DUPLICITY: . Attempt 1 failed. Error: g-io-error-quark: Error opening file: Operation not permitted (14)
So the error must be on the davfs side and you should investigate the server as locally there is nothing wrong at all.
Fabby
  • 35,017
